Hi Guys,
Today I tried V1.4.4, unfortunately when using Position Mode, it switches to Stabilize mode by itself without changing Flight Mode…
I see it changing in QGC.
Regards,
Pascal
Hi Guys,
Regards,
Pascal
Hi do you have log?
Is possible that you loose GPS lock, in that case autopilot switch to Stabilize
Hi David_Kraus
Unfortunately, I can not have the LOG.
Here are the symptoms, using QGC using Android Version
1- take-off in stabilize mode --> I switch it to POSITION and it works.
2- As soon as I move the stick, ROLL or PITCH, it switches back by itself to stabilize.
I will try to redo it and send the LOG so you can see what happens.
Next TOPIC I will post the LOG directly.
Regards,
Pascal
