am trying to receive drone position and display it on a QT GUI qlineedit.
I have the code for position, but the problem when I test it using px4 I received the position once, and I need a continuous movement. The code is same as the takeoff and landing example.
Mavsdk mavsdk;
ConnectionResult connection_result = mavsdk.add_any_connection("udp://:14540");
if (connection_result != ConnectionResult::Success) {
std::cerr << "Connection failed: " << connection_result << '\n';
return 1;
auto system = get_system(mavsdk);
if (!system) {
return 1;
// Instantiate pluginis.
auto telemetry = Telemetry{system};
auto action = Action{system};
// We want to listen to the altitude of the drone at 1 Hz.
const auto set_rate_result = telemetry.set_rate_position(1);
if (set_rate_result != Telemetry::Result::Success) {
std::cerr << "Setting rate failed: " << set_rate_result << '\n';
return 1;
telemetry.subscribe_position([&](Telemetry::Position position) {
emit updateAvAlt(position.relative_altitude_m);
emit updateAvLatLong(position.latitude_deg, position.longitude_deg);
and the emit call the display function.
void Status::setAvLatLong(double avLatitude, double avLonitude)
ui->avPos->setPosition(avLatitude, avLonitude);
void Status::setAvValueGreen()
ui->avPos->greenValue();
ui->avAlt->greenValue();
could you please help?
