I flashed the PX4 bootloader and firmware onto my Bitcraze Crazyflie 2.0 and now I want to start using the original Bitcraze firmware again. However, I’m unable to do this because PX4 is interrupting the flashing process. Is it possible to remove PX4?
Good day,
if your board have a jtag connector you can reflash the original bootloader. just in case you don’t have it soldered on your board you need the Bitcraze Crazyflie 2.0 debug adapter.
Thanks for the reply,
The CF2 appears to have that jtag connector you mentioned. I downloaded the original Bootloader from github (https://github.com/bitcraze/crazyflie2-stm-bootloader) and tried to ‘make’ it but I get the following message:
calums-MBP:crazyflie-bootloader-master calumboustead$ make
VER. version.c
abort: there is no Mercurial repository here (.hg not found)
sed: 1: “src/version.c”: unterminated substitute in regular expression
sed: -i may not be used with stdin
Build : () CLEAN
text data bss dec hex filename
6572 20 11040 17632 44e0 cloader.elf
Do you have any ideas on how to prepare the bootloader?
i don’t know how to help you coz im not using that fc… better you find the binary file
