# UAV drifts away when hovering based on optical flow
**URL:** <https://discuss.px4.io/t/uav-drifts-away-when-hovering-based-on-optical-flow/28601>\
**Created:** [August 5, 2022, 5:28pm UTC](https://discuss.px4.io/t/uav-drifts-away-when-hovering-based-on-optical-flow/28601 "2022-08-05T17:28:17Z")\
**Posts on this page:** 1\
**Showing post:** 2
**Author:** ![knolle](https://discuss.px4.io/letter_avatar_proxy/v4/letter/k/a9adbd/32.png) [@knolle](https://discuss.px4.io/u/knolle)\
**Post date:** [October 24, 2022, 11:14am UTC](https://discuss.px4.io/t/uav-drifts-away-when-hovering-based-on-optical-flow/28601/2 "2022-10-24T11:14:03Z")
Here’s an update of all what I have tried:
- (de-)tuning of optical flow sensor’s and rangefinder’s pitch offset (EKF2\_RNG\_PITCH)
- (de-)tuning of optical flow sensor’s and rangefinder’s x, y, z offsets (EKF2\_RNG\_POS\_, EKF2OF\_POS\_)
- (de-)tuning of optical flow sensor’s and rangefinder’s mounting roll, pitch and yaw
- (de-)tuning of optical flow sensor’s and rangefinder’s mounting x, y, z
- (de-)tuning of optical flow’s and rangefinder’s noise, delays, gate size (EKF2\_RNG\_NOISE, EKF2\_RNG\_DELAY. EKF2\_RNG\_GATE)
- increase and reduction of sensors’ mounting stiffness
- (un-)tick “optical flow” in EKF2\_TERR\_MASK
- (de-)activating COM\_HOME\_IN\_AIR
- use barometer instead rangefinder as primary height source (EKF2\_HGT\_MODE)
- enable & disable EKF2\_RNG\_AID
- auto PID tuning
- manual PID tuning (Velocity, Position)
- (un-)tick “inhibit IMU bias estimation” and “multi-rotor drag fusion” in EKF2\_AID\_MASK
- use “simple control mode” or “acceleration based input” in MPC\_POS\_MODE
- setting unused sensor’s EKF2 Delay parameters to zero (EKF2\_GPS\_DELAY etc.)
- changed values of EKF2\_BCOEF\_
- several sensor recalibrations
- flying indoor and outdoor
- different propellers
- different batteries
- different lightings
- use optical flow sensor and rangefinder on different drones of the same model
- use optical flow sensor and rangefinder on different drone models
None of the actions above brought significant improvement to reduce drift. By replacing the optical flow sensor with another optical flow sensor of the same model the drift direction and intensity changed. This leads to the conclusion that the drift is inherent in the sensor and possibly a lack of production quality.
I found the following related issues:
- [Unstable position hold using px4flow with pixhawk and QGC · Issue #5072 · PX4/PX4-Autopilot · GitHub](https://github.com/PX4/PX4-Autopilot/issues/5072)
- [Drone keeps moving left when in position hold mode with optical flow](https://discuss.px4.io/t/drone-keeps-moving-left-when-in-position-hold-mode-with-optical-flow/7832)
- [Reject position control, optical flow, LIDAR v3](https://discuss.px4.io/t/reject-position-control-optical-flow-lidar-v3/5872)
Possibly these are solved when you read this searching for solutions.
Best regards,
knolle
_[View the full topic](https://discuss.px4.io/t/uav-drifts-away-when-hovering-based-on-optical-flow/28601)._
