Tutorial: UOM Registration and Activation with QGroundControl and PX4
Hi everyone,
I’m sharing a UOM registration-verification and activation workflow that we integrated into a Linux QGroundControl build, together with a test flight controller and Remote ID (RID) firmware.
We used the UOM integration environment, simulated registration and a simulated product identifier, with QGC connected to the device. The recorded session completed the Appendix A interface-integration workflow.
The sequence is: verify registration → create a simulated registration → activate and report → deactivate and cancel registration → submit the platform’s integration-completion step. Registration status, device activation state and UOM report acknowledgements are checked separately throughout.
The screenshots show the original QGC integration build. Both the flight-controller and RID firmware were modified from PX4-Autopilot and ArduRemoteID. Software and firmware version notes are included near the end.
What the workflow covers
GB 46761—2025《民用无人驾驶航空器实名登记和激活要求》, Registration and activation requirements for civil unmanned aircraft, is a mandatory Chinese national standard published on October 31, 2025, effective May 1, 2026. See the official standard record and CAAC-published text.
This implementation follows the method 2 workflow described in the standard: the ground station communicates directly with UOM for registration verification and activation management. Appendix A provides the three interfaces used here:
Interface Purpose
A.2 Verify real-name registration status
A.3 Report activation state
A.4 Cancel registration
The owner completes identity verification and registration on UOM. QGC checks the aircraft’s registration status and coordinates device operations; it does not collect identity documents. Device firmware owns persistent activation state, and aircraft firmware must enforce the applicable flight restrictions.
Workflow at a glance
Keep QGC and the UOM integration page open together. At each stage, compare the device state, the latest interface result and the timestamp of the current operation before proceeding.
Stage QGC / device result UOM result to check
Before registration No registration record; Inactive A.2: No record
After simulated registration Registration normal; still Inactive Post-registration A.2 verification
After activation Activated; current activation report accepted A.3: Activated
After deactivation and cancellation Registration cancelled; Inactive; inactive-state report accepted A.4: Cancelled; refresh A.3 to Inactive
Completion No unfinished operation Final step completed in green, with the completion receipt
Figure 1. Source workflow diagram. Green stages are UOM checks, blue stages are QGC/device operations, and orange stages cover recovery. The diagram describes the sequence; aircraft-level restrictions still require separate test evidence.
1. Prepare the aircraft and integration access
You need a compatible Linux QGC build, flight-controller firmware with the device-management bridge, compatible RID firmware, and a RID already provisioned with the correct aircraft identity. Obtain manufacturer/producer access to UOM’s integration workflow, together with the environment’s producer ID, key ID and interface addresses.
Use a bridge-enabled flight-controller target and a compatible RID firmware target. A bench target that accepts mock reporting serves a different purpose from UOM’s simulated registration facility. Build-target identifiers and manufacturer-specific source links are omitted in this anonymized version.
Identity provisioning is a manufacturing prerequisite, outside this activation tutorial. Use your aircraft’s assigned identity throughout. The configured “expected SN” checks identity; it does not rewrite the RID’s factory identity.
2. Connect the aircraft and configure UOM
In the integration build, open Vehicle Configuration → RID → UOM real-name registration and activation. The flight view’s Remote ID status panel also provides an entry to UOM registration and RID management. English button names below translate the Chinese interface shown in the screenshots.
  1. Connect the aircraft and select Read RID devices. Wait for a successful readback.
  2. Check the product code/SN read from the RID against the aircraft being used for this session.
  3. In UOM’s GB 46761 interface interaction area, start the integration workflow for the test aircraft model and bind the same aircraft SN. If that session is already prepared, verify its existing binding.
  4. In QGC, select Configure UOM connection and enter the settings below.
  5. Select Save, then check the credential-storage message and reread the target identity if necessary.
Setting Value or check
Environment Integration
Producer ID / key ID Values issued for this integration environment
Expected aircraft SN Same as the UOM-bound SN and the SN read from the RID
Three interface URLs Match each address supplied for this environment
The recorded build used these endpoints:
A.2: https://uom.caac.gov.cn/api/uom-uavreg/eqgb/openapi/verifyRegisterFactory
A.3: https://uom.caac.gov.cn/api/uom-uavreg/eqgb/openapi/reportActiveStateFactory
A.4: https://uom.caac.gov.cn/api/uom-uavreg/eqgb/openapi/cancelRegisterFactory
These are the session’s integration settings. Use the addresses and credentials issued for your own environment. Before continuing, confirm a successful RID readback, matching SNs in all three places, Integration selected and the configuration saved. Expected aircraft SN checks identity; it does not rewrite the RID’s factory product code. If QGC reports session-only credential storage, re-enter the key after restarting QGC.
Figure 2. QGC RID page and UOM connection dialog. The environment, identity check and three interface fields are visible; identifiers and credentials are redacted.
Read these three QGC results separately throughout the session:
QGC result Meaning
Real-name registration Result of the latest registration verification
Device activation State read from the connected device
Latest UOM acknowledgement Result of the latest activation-state report
Check their timestamps. An old accepted report does not establish that the current operation succeeded, and the acknowledgement field is not a live query of platform activation state.
3. Run the pre-registration A.2 check
Start with an unregistered, inactive test aircraft.
  1. In QGC, select Check real-name registration.
  2. Confirm No registration record and Inactive, with a verification timestamp from this operation.
  3. On UOM’s GB 46761 integration page, select Refresh status beside A.2 and confirm No record.
  4. Compare the QGC and UOM registration results. Record the required pre-registration/pre-activation aircraft restriction checks using actual observations.
  5. Complete the platform’s checks and select Next.
A matching status result alone does not prove that firmware prevents flight; retain the separate aircraft-test record.
Figure 3. Before registration, QGC shows No registration record and Inactive, together with the verification time. Device identifiers are redacted.
4. Create and verify the simulated registration
In UOM, open Simulated real-name registration. If the aircraft already has a corresponding simulated record, inspect that record first. Otherwise:
  1. Select Add simulated aircraft registration.
  2. Use the magnifying-glass control beside Product model, search for the test aircraft’s assigned model and select its system-model record.
  3. Check the manufacturer, product name, category, aircraft type, empty weight and maximum takeoff weight shown for that model.
  4. Select Simulated unique product identifier and enter the same SN bound to this integration session.
  5. Fill in the required owner and registration fields and select Complete registration.
Figure 4. Saved registration-information view for the simulated test-aircraft record. Use it to check the model, selected simulated identifier option and recorded information. Registration identifiers, aircraft SN and personal fields are redacted.
Return to the platform list and confirm the record was created. Then return to QGC and select Check real-name registration again. The expected result is Registration normal, while the device remains Inactive. Simulated registration does not replace the separate device-activation operation.
Figure 5. After simulated registration, QGC reports Registration normal while the device remains Inactive. This is the expected state before activation.
5. Run the post-registration A.2 check and activate
  1. Return to UOM and refresh A.2 in the After real-name registration stage.
  2. Select Start verification for that stage.
  3. In QGC, select Activate aircraft.
  4. Recheck the target SN in the confirmation dialog, then confirm the intended operation.
Figure 6. Activation confirmation. Check the target aircraft before confirming; registration status and device activation remain separate states. Device identifiers are redacted.
Wait for the full chain: registration verification → device activation → confirmation that the device saved the state → matching readback → reporting to UOM.
Activation check Required result
Real-name registration Normal
Device activation Activated
Latest UOM acknowledgement Activation report accepted
Report timestamp Belongs to this operation
RID operation message RID activation saved and verified
Pending operation Completed; no unfinished operation awaiting retry
Figure 7. Activation saved and verified, with the activation report accepted. Check the device state, acknowledgement and current operation time together.
Use actual aircraft-test results to complete the platform’s registration-status consistency and post-activation flight-capability checks before moving on. If the aircraft still cannot arm, inspect the flight controller’s reported reason. RID health, flight-reporting readiness and other arming conditions still apply; QGC does not automatically change arming parameters.
6. Verify A.3 activation-state reporting
  1. Open Appendix A.3 — Activation-state reporting on UOM.
  2. Select Refresh status independently of the earlier QGC operation.
  3. During the activated stage, confirm Activated. Compare it with QGC’s Activated device state and the acknowledgement/timestamp of the current successful report.
  4. Complete the platform’s checks for agreement with the interface result, state synchronization and actual aircraft capability using the corresponding test records.
  5. Select Next to enter A.4.
The source platform screenshot available for review was captured later, after cancellation had begun. It appears in Figure 10 below; its earlier A.3 Activated value must be distinguished from the refreshed final state in Figure 11.
7. Deactivate the device and cancel registration
Keep the target aircraft on the ground and disarmed.
  1. Confirm QGC still has Integration selected.
  2. Select Deactivate and cancel registration.
  3. Choose the actual reason. This session used Other reason, with an explanation equivalent to: “GB46761 interface integration: deactivation and registration-cancellation test.”
  4. Recheck the target SN and select the checkbox confirming the target aircraft and registration cancellation.
  5. Select OK to submit the intended operation.
Figure 8. Cancellation dialog with Other reason, the explanation and the target-aircraft confirmation selected. Identifiers are redacted; other sessions should use their actual reason.
QGC proceeds in order: deactivate the device → verify its saved state → report Inactive to UOM → request registration cancellation.
Cancellation check Required result
Real-name registration Registration cancelled
Device activation Inactive
Latest UOM acknowledgement Inactive-state report accepted/confirmed
RID operation message RID deactivation saved and verified
Overall status RID inactive; UOM registration cancelled
Figure 9. Completed deactivation and cancellation: Registration cancelled, Inactive and a confirmed inactive-state report.
8. Refresh A.4 and reconcile the final platform state
Return to UOM. The following review screen shows why each interface result needs its own refresh: A.4 has already returned Cancelled, while A.3 still displays its earlier Activated value.
Figure 10. Later review screen: A.3 retains the earlier Activated result and A.4 shows Cancelled. This is not a simultaneous final-state verification. Refresh activation state before accepting the final result.
  1. Select Refresh status beside A.4 and confirm Cancelled.
  2. Compare the cancellation reason and explanation with what was submitted in QGC.
  3. Refresh activation state/A.3 and confirm Inactive, matching the device.
  4. Complete the four platform checks below using the actual observations, then select Next.
Platform check Evidence to retain
Registration state agrees with the interface UOM Cancelled matches QGC Registration cancelled
Activation state agrees with the interface UOM and device both show Inactive
State synchronization agrees with actual aircraft capability Correct synchronization plus the corresponding aircraft-test record
Aircraft cannot fly after deactivation Actual evidence that the applicable restriction took effect
Figure 11. After refresh, A.3 shows Inactive and A.4 shows Cancelled. The Complete integration button is visible, but its presence is not proof that the final submission succeeded.
Cancelled registration and an inactive device are the expected final states of this test. The final A.3 Inactive result does not contradict the Activated report verified earlier in the sequence.
9. Submit Complete integration and retain the receipt
  1. After completing the required platform checks, enter the fourth platform step and select the blue Complete integration button.
  2. Wait for the final submission result.
  3. Confirm that the fourth step has a green completion mark and that the page reports completion of the GB 46761 Appendix A interface integration for the selected model.
  4. Save that final page together with QGC’s final states, software/firmware identifiers and the aircraft-test records.
Our final page also identified subsequent steps for the conformity declaration, review and production-environment access.
Figure 12. Final receipt from the integration environment, after submission. The selected platform checks belong to the submitted record; independent aircraft-test evidence is needed to substantiate flight restrictions.
This interface-integration result does not by itself establish production onboarding, whole-aircraft conformity, restart/update retention or interface performance.
10. Recover from a RID timeout
During the recorded activation and cancellation operations, QGC sometimes displayed:
RID did not respond before the deadline
First reread the RID and verify that it is the same aircraft. Then use the branch that matches the current situation:
Situation Recovery action Check before declaring recovery
No Retry pending operation button Read the RID successfully, confirm its identity, then initiate the intended operation again Fresh device state, current acknowledgement and timestamps
Retry pending operation is available Reread the same RID; open the retry dialog and inspect the pending action, target SN and current state before confirming The pending action matches the intended operation; the current operation completes without remaining pending work
Device reads also keep timing out Stop submitting further operations and check RID power, connections, communications and logs Stable device communication is restored first
Timeouts repeat after recovery Preserve error times and QGC, flight-controller and RID logs to locate the unresponsive stage Do not claim success from an old state or acknowledgement
QGC has restarted Restore the correct environment’s key if credentials were session-only, then recheck configuration and pending state Correct environment, SN, credentials and intended pending action
Be especially careful with a pending cancellation: retrying it can submit cancellation again. If activation was intended, cancel that confirmation and reconcile QGC/UOM state before proceeding.
The recorded build displays a minimum one-minute interval for identical UOM requests. Respect the interval shown by QGC; repeated clicks do not bypass it. This request throttling is separate from the RID response deadline and does not mean every RID timeout requires the same wait.
The session notes identify flight-controller firmware as v1.18.0 and correct the RID firmware version to 1.17 (the original record lists 1.7). The PX4 firmware came from a development branch rather than the stock v1.18.0 release.
The record does not capture the exact flashed-binary hashes or QGC executable commit. Manufacturer-specific repository URLs and branch names are omitted from this anonymized article.
Next steps and community feedback
Activation-state reporting is already part of this workflow. I plan to extend the work with UOM flight-information reporting and share further integration results as they become available.
I’d welcome feedback on the registration/activation UI, the firmware and device-adapter interfaces, and recovery after interruptions. If you reproduce a similar integration, please include your software revisions, hardware configuration and environment, expected result and observed behavior in feedback, with credentials and personal information removed.
I hope this walkthrough helps others working on similar integrations compare their results and improve the workflow together.
I’d like to clarify the software and firmware setup used in this tutorial and share the corresponding development branches:
Component Build used in the integration session Source branch
QGroundControl A custom Linux build with UOM registration and activation support QGC integration branch
PX4 flight-controller firmware A customized development-branch build, recorded as v1.18.0 PX4 device-management branch
RID firmware A modified ArduRemoteID-based build, version 1.17 RID device-management branch
The RID firmware entry in the earlier integration notes should read 1.17, rather than 1.7.
This workflow depends on coordinated changes across QGC, the flight-controller firmware and the RID firmware, including UOM interface handling, the device-management bridge and persistent activation-state management. Reproducing it requires compatible custom builds of all three components. Stock upstream releases with similar version numbers may not include these changes.
The links above point to development branches, which may receive further updates. The exact QGC executable commit and the hashes of the flashed firmware binaries were not recorded for this session. For reproducibility, please record the source revisions, build configuration and firmware binary hashes together.
Thanks for sharing this — helpful overview.
