Hello
I have acquired a TinyPICO ESP32 Development Board for wifi telemetry. I followed the instructions in https://docs.px4.io/main/en/telemetry/esp32_wifi_module.html. However, I have some troubles, because the wifi network is hardly visible (most of the time not, and no chance to connect). I am not quite sure whether I have connected the board correctly. Where do I have to connect the TX/RX lines?
TinyPICO is not compatible with the standard build of the DroneBridge for ESP 32 software. Pin 17 is used internally and any attempt to use it for TX/RX will crash the board.There is a custom build which works with TinyPICO at https://github.com/DroneBridge/ESP32/files/9126695/DB_ESP32_ALT_UART.zip.
Many thanks to the maintainer of DroneBridge to provide this custom build.
