Strobe Lights
Hello, I need to have strobe lights that come on upon the vehicles release from the main RC aircraft. My plan was to attach LEDs to the servo rail and power it that way, would that work?
It would work, but I would use a separate BEC power depending on how much power your LEDs consume. the last think you want is to lose flight critical power because your LEDs are consuming too many amps
The thread discusses the challenge of integrating strobe lights with PX4 systems. A common solution involves using a separate Battery Elimination Circuit (BEC) to ensure the lights do not interfere with the main flight systems. This setup ensures both safety and functionality, especially for vehicles needing clear visual signals.
