Send position from ros2 topics to mavlink messages
Hey, im using sitl simulation and gazebo. im trying to send the position i get from the gazebo to the mavlink, im trying to send the position to LOCAL_POSITION_NED (32) with publisher i create on ros.
when i send the message from ros to mavlink the position doesnt change, does anyone do something similar and can help?
this is the code to send the message :
import rclpy
from rclpy.node import Node
from nav_msgs.msg import Odometry
from pymavlink import mavutil
import time
class PoseToMavlink(Node):
    def __init__(self):
        super().__init__('pose_to_mavlink')
        self.start_time = time.time()
        self.connection = mavutil.mavlink_connection("udp:127.0.0.1:14555")
        self.get_logger().info("Waiting for heartbeat from SITL...")
        self.connection.wait_heartbeat()
        self.get_logger().info(f"✅ Heartbeat received from system {self.connection.target_system}")
        self.subscription = self.create_subscription(Odometry, "/ariel/pose_gt", self.pose_callback, 10)
        self.timer = self.create_timer(0.1, self.send_mavlink_local_position)
        self.current_pose = None
        self.current_velocity = None
    def pose_callback(self, msg):
        self.current_pose = msg.pose.pose.position
        self.current_velocity = msg.twist.twist.linear
    def send_mavlink_local_position(self):
        if self.current_pose is None:
            return  # No data received yet
        time_boot_ms = int((time.time() - self.start_time) * 1000)
        x_ned, y_ned, z_ned = self.enu_to_ned((self.current_pose.x, self.current_pose.y, self.current_pose.z))
        vx_ned, vy_ned, vz_ned = self.enu_to_ned((self.current_velocity.x, self.current_velocity.y, self.current_velocity.z))
        # ✅ Send `LOCAL_POSITION_NED` message
        self.connection.mav.local_position_ned_send(
            time_boot_ms,  # Timestamp (ms)
            x_ned, y_ned, z_ned,  # Position (NED)
            vx_ned, vy_ned, vz_ned  # Velocity (NED)
        self.get_logger().info(f"📡 Sent LOCAL_POSITION_NED: x={x_ned}, y={y_ned}, z={z_ned}, vx={vx_ned}, vy={vy_ned}, vz={vz_ned}")
    def enu_to_ned(enu):
        x_enu, y_enu, z_enu = enu
        return y_enu, x_enu, -z_enu
def main():
    rclpy.init()
    node = PoseToMavlink()
    rclpy.spin(node)
    node.destroy_node()
    rclpy.shutdown()
if __name__ == "__main__":
    main()
