Hello, I’m trying to send Mavlink message in UDP port; this is the code i use :
int main()
char help[] = "--help";
char target_ip[100];
int sock = socket(PF_INET, SOCK_DGRAM, IPPROTO_UDP);
struct sockaddr_in gcAddr;
struct sockaddr_in locAddr;
//struct sockaddr_in fromAddr;
uint8_t buf[BUFFER_LENGTH];
socklen_t fromlen = sizeof(gcAddr);
int bytes_sent;
mavlink_message_t msg;
uint16_t len;
/* Bind the socket to port 14551 - necessary to receive packets from qgroundcontrol */
if (-1 == bind(sock, (struct sockaddr *)&locAddr, sizeof(struct sockaddr)))
perror("error bind failed");
exit(EXIT_FAILURE);
memset(&gcAddr, 0, sizeof(gcAddr));
gcAddr.sin_family = AF_INET;
InetPton(AF_INET, _T("127.0.0.1"), &gcAddr.sin_addr.s_addr);
gcAddr.sin_port = htons(14550);
while(1)
/*Send Heartbeat */
mavlink_msg_heartbeat_pack(1, 200, &msg, MAV_TYPE_HELICOPTER, MAV_AUTOPILOT_GENERIC, MAV_MODE_GUIDED_ARMED, 0, MAV_STATE_ACTIVE);
len = mavlink_msg_to_send_buffer(buf, &msg);
bytes_sent = sendto(sock, buf, len, 0, (struct sockaddr*)&gcAddr, sizeof(struct sockaddr_in));
/* Send Status */
mavlink_msg_sys_status_pack(1, 200, &msg, 0, 0, 0, 500, 11000, -1, -1, 0, 0, 0, 0, 0, 0);
memset(buf, 0, BUFFER_LENGTH);
i get the error “Error (active) E0167 The argument of type “uint8_t (*) [2041]” is incompatible with the parameter of type “const char *”” about the variable buf in sendto.
Any help ?
