Hi everyone,
I would like to automate some tests in HITL using MAVSDK.
For this I would like to read and write the parameters.
I started from the example takeoff_and_land, and I added the following line of code:
#include <mavsdk/plugins/param/param.h>
, at the top of the file -
auto param = std::make_shared<Param>(system);
right after the declaration oftelemetry
andaction
std::pair<Param::Result, float> result = param->get_param_float("MIS_TAKEOFF_ALT");
to read the parameterMIS_TAKEOFF_ALT
if (result.first != Param::Result::Success) {return 1};
and stop the program if it fails.
after a make
command, I get the following errors
undefined reference to mavsdk::Param::get_param_float()
, but I includedparam.h
@JulianOes any tips ? or any example code to read/write parameters ?
Thanks,
Romain
(full make
command output)
Scanning dependencies of target takeoff_and_land
[ 50%] Building CXX object CMakeFiles/takeoff_and_land.dir/takeoff_and_land.cpp.o
[100%] Linking CXX executable takeoff_and_land
CMakeFiles/takeoff_and_land.dir/takeoff_and_land.cpp.o: In function `main':
takeoff_and_land.cpp:(.text+0xa24): undefined reference to `mavsdk::Param::get_param_float(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) const'
CMakeFiles/takeoff_and_land.dir/takeoff_and_land.cpp.o: In function `void __gnu_cxx::new_allocator<mavsdk::Param>::construct<mavsdk::Param, mavsdk::System&>(mavsdk::Param*, mavsdk::System&)':
takeoff_and_land.cpp:(.text._ZN9__gnu_cxx13new_allocatorIN6mavsdk5ParamEE9constructIS2_JRNS1_6SystemEEEEvPT_DpOT0_[_ZN9__gnu_cxx13new_allocatorIN6mavsdk5ParamEE9constructIS2_JRNS1_6SystemEEEEvPT_DpOT0_]+0x48): undefined reference to `mavsdk::Param::Param(mavsdk::System&)'
collect2: error: ld returned 1 exit status
CMakeFiles/takeoff_and_land.dir/build.make:97: recipe for target 'takeoff_and_land' failed
make[2]: *** [takeoff_and_land] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/takeoff_and_land.dir/all' failed
make[1]: *** [CMakeFiles/takeoff_and_land.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
