Hello guys,
I am new to Pix4 and QGroundControl, right now I am facing a problem that the channel signal is not stable. Jump between its desired level and 0.
I used analyze window and found out this situation:
But it didn’t happen at first time, and once after I reassign channel on the transitter, problem shift from channel 3 to channel 6, so I dno’t think it’s a hardware issue.
I also tried rebind and reset all parametters. Not working.
Any ideas would be appreciate.
Thanks.
