hello everyone
I meet a question about the world files in SITL.
when I use UAV simulation in gazebo, the some parameters in world file are:
<max_step_size>0.004</max_step_size>
<real_time_factor>1</real_time_factor>
<real_time_update_rate>250</real_time_update_rate>
when I add other robot models such as manipulator in this world, the UAV works well, but other robots maybe work bad.
the main problem is:
<max_step_size> and <real_time_update_rate>
I konw px4 needs that:
but other robots or some plugins need:
<max_step_size>0.001</max_step_size>
<real_time_update_rate>1000</real_time_update_rate>
I have a plugin (vacuum) on manipulator , and when the max_steo_size is 0.004, vacuum can’t work well.
I use vacuum by libgazebo_ros_vacuum_gripper.so in xacro file, so I can not modify the parameters in .so file.
how can I fix this problem?
