QGC connection with G12 skydroid transmitter
How to connect skydroid g12 to QGC as it’s not getting updated on the QGC
I ma not using Skydroid H12Pro which I believe is similar to G12. In the Skydroid Help App try changing the Baud Rate to 57600. when the baud rate is correct QGC normally connects automatically. Make sure that you do not have any other skydroid apps running at the same time.
The problem was not the baud rate it was automatically figured out by MP but the telemetry wiring which was incorrect and I matched the Connections by using the concerned manuals.
Good to know you got it working. Skydroid make good equipment but unfortunately I find the documentation is lacking.
QGC is not working with gimbal can you Pls let me know how to get it done?
You cannot control the camera/gimbal using qgc. However, you can using the RC control channels. You first need to configure the camera via the SkydroidCameraFPV.apk. Go to setup button and then select “Pan Tilt Control” and at the bottom select “Customizing Remote Control Buttons”, from here you can assign a RC channel to a camera function.
Hope this helps
