I’m installing the toolchain on a fresh macOS Catalina system.
The toolchain compiles fine on Master.
But when I’m trying to compile on v1.10 with git checkout v1.10 followed by make px4_fmu-v5 I get the following error Failed to import yaml. You may need to install it with 'sudo pip install pyyaml'
The packages yaml is already installed in /usr/local/lib/python3.8/site-packages
I tried to install it many times.
I also tried to install the packages inside pipenv, but the error message remains.
Yes by typing type -a python2 I get python2 is /usr/bin/python2,
I tried removing /usr/bin from PATH, but then the make command is not recognized.
From what I know PATH is used by several applications so I don’t want to alter it.
Any suggestions?
You can try modifying the PYTHONPATH env variable to hold the path for python 3.x only; for example: export PYTHONPATH=/usr/local/lib/python3.8/site-packages or /usr/local/lib/python3/site-packages. Other possibilities are: /usr/lib/python3.8/site-packages, or similar names using dist-packages instead of site-packages (if you have those). You may combine all of them in PYTHONPATH using colons ( : ), like this: export PYTHONPATH=option0:option1:option2:etc.
