Hello everyone,
I got a problem while doing the build , deploy and start on Simulink ( matlab2021a) i’ve got an error while deploying . ( Ninja build stopped: subcommands failed)
Any solutions ?
THANK YOU
Actually it says the reason for fail. I got the same reason for not existing nuttx files in ubuntu. However, i solved my problem by switching into windows and then rebuilding it. There are also several reasons for that. Someone said that the reason was being long path name. So, there is no single solution for that.
Firstly, please look in details of error. There must be the name of missing files. Then, just try to put your current folder in C:/, without any other folder.
Sincerely,
