PX4 Fixed-Wing AUTO Takeoff — No Rotation Command on Flying Wing
We’re debugging AUTO takeoff behavior on a separate fixed-wing flying-wing test platform and are seeing an issue where PX4 never commands a rotation.
In AUTO mode with a standard TAKEOFF mission item:
  • The aircraft reaches the takeoff point correctly
  • Throttle commands behave as expected
  • Elevons remain neutral
  • No pitch-up or rotation command is ever generated
Manual and stabilized modes work normally, so control surfaces, mixing, and authority are confirmed to be correct.
We’ve tried adjusting RWTO_TKOFF, TKOFF_THR, and related parameters without any change in behavior, and the mission item appears to be set up correctly.
Relevant details:
  • Flying wing (no dedicated elevator, only elevons)
  • No airspeed sensor installed
  • Bench and ground tests performed with lowered takeoff speeds
What we’re unclear on is:
  • What exact conditions PX4 requires before commanding rotation during AUTO takeoff
  • Whether the lack of an airspeed sensor can suppress the pitch-up command
  • Whether flying wings are handled differently from conventional fixed-wing aircraft
  • Whether rotation commands should be observable during bench or low-speed testing, or if PX4 suppresses them until specific airspeed/attitude conditions are met
Documentation on the rotation logic and prerequisites for AUTO takeoff is fairly vague, so any insight into expected behavior here would be appreciated.
Can you share a log via logs.px4.io where you see the issue?
Note: We believe the crash occured around 26:31.5. We had set FW_TKO_AIRSPD to 10 m/s which it clearly reached before it crashed and yet no pitch command was seemingly issued before it crashed.
Before trying out mission mode the first time, had you carefully tried and tuned altitude and then position mode at all? If not, I would be very surprised if mission just works out of the box.
