# Audit of my PX4 pull requests, 2026-10-13 21:54Z
On 2026-10-13 around 15:40Z,… 21 of my open PRs were closed in one sweep, and between 15:54Z and 17:10Z dakejahl merged 16 others (thank you); by 18:03Z he had closed the last two open ones as well, one of them superseded by his own board-level fix (#29198). In between we talked on #29151: 61 PRs in a day is a tax on reviewers, some are good bug fixes, some are pointless edge cases, and I should do that sorting myself before asking for anyone's time. Agreed. This is that sorting, done after the fact for everything I filed, with the evidence in one place so nobody has to re-derive it. One issue instead of 43 comments; nothing has been touched on the PRs since.
What I did for each PR:
1. Re-read the claim against today's main and wrote down the lines and the input that reaches them.
2. Built the branch in your CI container (`px4io/px4-dev:v1.16.0-rc2-4-gb67c65bfe6`): `make check_format`, `px4_sitl_test` with the whole ctest suite, `px4_fmu-v6x_default`; then once more merged with current main, plus `px4_sitl_allyes`, so the -Werror configurations are covered.
3. For the PRs that carry tests: applied only the test hunks to current main and ran them (red expected), then built and ran them on the branch (green expected).
4. Had an independent model (DeepSeek v3.2 on Vertex, prompted as a skeptical PX4 maintainer) try to knock each one down, and checked every objection in the code. Where it was wrong I say so. Then a second pass of small Claude agents verified every line reference and claim in this document against the code, and I fixed what they found.
5. Wrote a verdict: WORTH IT, NEEDS WORK, MARGINAL, NOT WORTH IT, or CONCEDED. Where I concede, I concede, and I will not re-file those.
For the closed ones I still rate WORTH IT, the facts are in the comments below; if any of them reads as worth a second look, I will bring it back one at a time, spaced out, and otherwise they stay closed. About AI use: all of these PRs were written with AI assistance (Claude: claude-fable-5-1 for everything from 10/12 and 10/13, claude-opus-4-8 for #29070). docs/en/contribute/ai_assistants.md asks for an `Assisted-by` trailer on every such commit. Most of my commits from those two days don't have it and neither do the squash commits of the merged ones. An earlier version of this issue said every commit carried it. That was wrong. This is the disclosure for all of them, each PR description now says it too, and every commit I make from here on carries the trailer. The verification was run by me on my machines; the numbers are mine.
## Score
WORTH IT: 17 | MERGED: 15 | MARGINAL: 4 | WITHDRAWN: 3 | NOT WORTH IT: 2 | CLOSED: 2 | CONCEDED: 2 | REAL: 1
| PR | what | state | verdict | ask |
| gps247 | GPSDrivers #247 fix(erb,femtomes): accept only frames that carry the m | OPEN (PX4/PX4-GPSDrivers) | WORTH IT | review |
| #29116 | fix(collision_prevention): keep obstacle-map bin index in range for un | CLOSED by dakejahl 15:39Z (n | WORTH IT | worth a second look, I think |
| #29117 | fix(rc/sumd): store channel data from index 0 so 32-channel frames fit | CLOSED by dakejahl 15:39Z | MARGINAL | your call |
| #29118 | fix(mavlink): bound SERIAL_CONTROL count before serial passthrough | CLOSED by dakejahl 15:39Z | WORTH IT | worth a second look, I think |
| #29119 | fix(mavlink): answer REQUEST_EVENT ranges beyond the event buffer with | CLOSED by dakejahl 15:39Z | WORTH IT | worth a second look, I think |
| #29120 | fix(mavlink): clamp the stream interval for very low requested rates | CLOSED by dakejahl 15:39Z | NOT WORTH IT | stays closed, agreed |
| #29122 | fix(commander): validate ARM_DISARM and DO_SET_MODE parameters before | CLOSED by dakejahl 15:40Z | NOT WORTH IT | stays closed, agreed |
| #29123 | fix(collision_prevention): read at most 72 distances from a body-frame | CLOSED by me 15:36Z as a dup | CLOSED | done |
| #29124 | fix(ekf2): deny a sensor-enable command whose parameters are out of ra | CLOSED by dakejahl 15:40Z | MARGINAL | your call |
| #29125 | fix(ekf2): ignore an external wind reset with a non-finite speed or di | CLOSED by dakejahl 15:40Z | MARGINAL | your call |
| #29127 | fix(airframes): set CA_ROTOR_COUNT for crazyflie21, jsbsim hexarotor a | CLOSED by dakejahl 16:16Z (n | WORTH IT | worth a second look, I think |
| #29128 | fix(srgbled_dma): read only the LED packages the caller provides | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29129 | fix(navigator): scale the heading timeout before casting it to microse | CLOSED by dakejahl 15:49Z | WORTH IT | worth a second look, I think |
| #29130 | fix(control_allocator): clamp the control surface and tilt counts to t | MERGED by dakejahl 17:10Z as | MERGED | merged, thank you |
| #29131 | fix(flight_mode_manager): address the gimbal control request to the co | MERGED by dakejahl at 16:15Z | MERGED | merged, thank you |
| #29132 | fix(tunes): return defined note fields for rests and repeated tunes | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29133 | fix(commander): treat a required GNSS count above the two receivers as | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29134 | fix(mavlink): refuse a message-interval id that does not fit the strea | CLOSED by dakejahl 17:23Z (n | WORTH IT | worth a second look, I think |
| #29136 | fix(rc_input): match the RC_SCAN values to the RC_INPUT_PROTO paramete | MERGED by dakejahl at 16:42Z | MERGED | merged, thank you |
| #29137 | fix(boards): corvon 743v2 names the MS4525DO driver by its Kconfig sym | CLOSED by me (the author) at | CLOSED | done |
| #29138 | fix(navigator): loiter at the current position for LOITER_TO_ALT witho | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29139 | fix(navigator): reset the VTOL takeoff transition direction per comman | MERGED by dakejahl at 16:44Z | MERGED | merged, thank you |
| #29140 | fix(commander): index external check registrations by their slot | MERGED by dakejahl at 16:28Z | MERGED | merged, thank you |
| #29141 | fix(motion_planning): clamp the waypoint angle cosine before acosf | MERGED by dakejahl at 16:49Z | MERGED | merged, thank you |
| #29142 | fix(mathlib): reject a notch bandwidth at or above half the sample rat | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29143 | fix(sensors): keep the magnetometer inconsistency filters finite | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29144 | fix(vl53l1x): bound the data-ready wait during sensor init | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29146 | fix(gyro_fft): drop the unsupported 4096 FFT length from the metadata | MERGED by dakejahl at 16:42Z | MERGED | merged, thank you |
| #29147 | fix(commander): correct the MOTFAIL_C2T unit and the stale names in th | CLOSED by me (the author) at | WITHDRAWN by me | closed by me, nothing to do |
| #29149 | fix(rc): clamp S.Bus output values below the scale offset | MERGED by dakejahl at 16:31Z | MERGED | merged, thank you |
| #29150 | fix(rc): read PWM RSSI from the last RC channel | MERGED by dakejahl at 16:49Z | MERGED | merged, thank you |
| #29151 | fix(rc): send GHST ground speed and course in the frame's units | MERGED by dakejahl at 16:12Z | MERGED | merged, thank you |
| #29152 | fix(mb12xx): zero-initialise the published distance_sensor report | MERGED by dakejahl at 16:12Z | MERGED | merged, thank you |
| #29156 | fix(control_allocator): zero non-finite torque setpoint components | MERGED by dakejahl at 16:59Z | MERGED | merged, thank you |
| #29157 | fix(logger): keep the log cleanup within its limits | MERGED by dakejahl at 16:25Z | MERGED | merged, thank you |
| #29158 | fix(uavcan): ignore MAV_CMD_PREFLIGHT_STORAGE while armed | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29159 | fix(navigator): walk the landing pattern without DO_JUMP in mission-la | CLOSED by dakejahl 15:47Z | WORTH IT | worth a second look, I think |
| #29160 | fix(uavcan): count DroneCAN node parameters beyond 255 | CLOSED by dakejahl 15:40Z | WORTH IT | worth a second look, I think |
| #29161 | fix(mavlink): drop a DroneCAN parameter request that gets no reply | MERGED by dakejahl at 16:08Z | MERGED | merged, thank you |
| #29162 | feat(mavlink): make the mission transfer retry timeout a parameter | CLOSED by me (the author) at | WITHDRAWN by me | closed by me, nothing to do |
| #29163 | fix(px4io): apply the servo rail voltage scale register | CLOSED by dakejahl 15:40Z | MARGINAL | your call |
| #29165 | fix(tecs): keep the roll-to-throttle compensation out of the energy ra | CLOSED by me (the author) at | WITHDRAWN by me | closed by me, nothing to do |
| #29166 | fix(mtd): fit the partition table to a smaller FRAM | CLOSED by dakejahl 18:03Z, s | CONCEDED | agreed, nothing to do |
| #29167 | fix(lightware): consume exactly the parsed frame | MERGED by dakejahl at 16:08Z | MERGED | merged, thank you |
| issue-29153 | Issue 29153 EKF2_AGPn_CTRL is documented as a bitmask but only tested | OPEN issue (mine); fix filed | REAL | fix filed, your call |
| issue-29154 | Issue 29154 Battery with unconfigured cell count (BATn_N_CELLS=0) is r | CLOSED by dakejahl 16:59Z (" | CONCEDED | agreed, nothing to do |
## Context
Merged today or earlier (24): #29070, #29121, #29126, #29130, #29131, #29135, #29136, #29139, #29140, #29141, #29145, #29146, #29148, #29149, #29150, #29151, #29152, #29155, #29156, #29157, #29161, #29164, #29167, #29190.
Who closed what: taken from each PR's GitHub timeline (issues/N/events), not guessed; the 21 closures between 15:39:53Z and 15:49:44Z and #29127 at 16:16Z are dakejahl's, #29147, #29162 and #29165 are mine.
Superseded (20): #29030-#29115 were closed by GitHub when my fork was deleted by mistake on 2026-10-13 02:36Z and re-filed with the same commits as #29116 and up; they are not separate work.
## Follow-up commits made during this audit (pushed to the PR branches together with this issue; the two withdrawn ones stay local)
| PR | branch | commit | what |
| 29117 | fix/rc-sumd-32-channels | c4de9092f | the 32-channel test now checks the four reordered channels too |
| 29119 | fix/mavlink-request-event-range | 0d92c51f5 | REQUEST_EVENT window: empty request answered with nothing, a request beyond the latest sequence with one error for its first sequence, the older part with one error, then at most capacity() replies (third revision, simulated) |
| 29124 | fix/ekf2-sensor-enable-param-range | bb5b4f481 | comment reflowed to 120 columns; a non-finite instance means unused; the first commit's body now says the instance check also denies an out-of-range instance for sources that ignore it (message-only amend, same tree) |
| 29125 | fix/ekf2-external-wind-nonfinite | 589fa4653 | comment gives the speed reason too |
| 29130 | fix/control-allocator-count-clamp-warning | c4fb45675 | filed as #29203: plain comparisons instead of math::constrain, because the merged #29130 trips GCC's -Werror=dangling-pointer and main's allyes builds have been red since 17:10Z; reproduced and verified clean with GCC 13.3 |
| 29133 | fix/gnss-required-count-clamp | c89cb7e8f | test comment trimmed to what the case checks |
| 29138 | fix/loiter-to-alt-current-position | aff6c3a28 | the reverse fast Return resolves a current-position loiter too; test comments name the rejecting check and say the download claim is checked against the cache only |
| 29142 | fix/notch-filter-bandwidth-nyquist | 7fb002d89 | comment states exactly when the guard matters, within 120 columns |
| 29143 | fix/mag-inconsistency-nan | 148d27271 | new gtest case: a NaN sample leaves the inconsistency filters finite (red on main, green on the branch); the no-reference comment covers the all-non-finite cycle |
| 29144 | fix/vl53l1x-init-data-ready-timeout | f0d3bdc1e | a failed status read ends the data-ready wait at once, like every other I2C error in init(); the comment says so |
| 29151 | fix/ghst-telemetry-gps-units | 6daefc06b | ghst.hpp doc comment states the frame units (cm/s, 0.1 deg) |
| 29158 | fix/uavcan-preflight-storage-armed | da0bb6611 | gate on armed only (Commander's rule), firmware server keeps armed-or-prearmed |
| 29160 | fix/uavcan-param-count-width | 7d84d5bed | a node answering at the last index (8191) completes the count at 8192, guard placed before the next request is built; the index constant sits above its doc block |
| 29165 | fix/tecs-load-factor-feedforward | 1cf117764 | WITHDRAWN with the PR (closed by the author 16:19Z); the local rebase carries main's new tests intact plus the new case; test comment, TECS.cpp comment and commit body no longer say the proportional term winds up |
| gps247 | fix/payload-length-checks (PX4-GPSDrivers) | 5f558b1 | no minimum payload for VERSION frames (the handler reads none); femto test comment says what it truncates; pushed to the PR |
| issue-29153 | fix/ekf2-agp-ctrl-bitmask | 60e46f051 | new branch: the source's available flag gated on bit 0; bit 1 documented as reserved (no vertical fusion path; the altitude only seeds the origin); common.h comment says AGP reads bit 0 |
| issue-29154 | fix/battery-unknown-soc-not-emergency | 28e1eb593 | WITHDRAWN: the maintainer closed #29154 as intended safety behaviour; branch kept locally only |
They went up together with this issue; the closed PRs show them as new commits, nothing is reopened, and the 29153 fix is the one new PR.
The entries for the PRs that still ask for a decision (WORTH IT, MARGINAL, NOT WORTH IT, the open issue, the conceded one) are in the comments below; the merged and withdrawn ones are only in the table above. The full dossier with every entry: https://gist.github.com/trestoncuzzort/2fcc9508e5182b0dd1e59dfe69178986
## Machine evidence, raw
Branch heads as filed, CI container (pass 1, stopped after ten branches to make room for pass 2):
Each branch merged with current main: check_format, px4_sitl_test with every ctest, px4_sitl_allyes, px4_fmu-v6x_default. CI container, as filed plus the local follow-ups:
pending
CI container, the final heads of the branches that carry follow-up commits:
pending
pending
pending
Lab, native toolchain (GCC 13.3, Arm GNU 13.3.rel1):
main=2d7f7e029f 17:06Z
fix/collision-prevention-wrap-bin f652fd4411 merge=ok format=ok sitl=ok tests=ok allyes=FAIL v6x=ok 100% tests passed, 0 tests failed out of 215 17:10Z
fix/rc-sumd-32-channels 8c9a67e0f5 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:14Z
fix/mavlink-serial-control-count 9106bf6b81 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:18Z
fix/mavlink-request-event-range 75ed3da541 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:21Z
fix/ekf2-sensor-enable-param-range 484d183bc9 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:24Z
fix/ekf2-external-wind-nonfinite fcacb6fed6 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:27Z
fix/neopixel-write-count 75cd165f64 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:30Z
fix/mission-yaw-timeout-cast 12e9f2aecd merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:34Z
fix/tunes-rest-outputs f466df6796 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 216 17:37Z
fix/gnss-required-count-clamp eb0f32b188 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:40Z
fix/loiter-to-alt-current-position 4466db16c9 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:43Z
fix/notch-filter-bandwidth-nyquist fadf7b7a50 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:46Z
fix/mag-inconsistency-nan f85da886da merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:49Z
fix/vl53l1x-init-data-ready-timeout c187e71346 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:53Z
fix/uavcan-preflight-storage-armed d8edde7d43 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 17:56Z
fix/rtl-direct-mission-land-do-jump 2b42130160 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 216 17:59Z
fix/uavcan-param-count-width c9adc187b2 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 18:02Z
fix/px4io-vservo-scale 12ddc3caa0 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 18:05Z
LAB PASS2 DONE 18:05Z
main=2d7f7e029f 18:06Z
fix/collision-prevention-wrap-bin f652fd4411 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 18:09Z
LAB PASS2 DONE 18:09Z
Lab, the same checks on the heads amended after the second verification pass (comment and commit-message corrections, one guard moved), merged with the 21:10Z main plus #29203 (without it main's allyes builds fail on the #29130 dangling-pointer error, which is what the first attempt at 21:26Z showed for the first branch):
main=633af12ea4+29203(c4fb456753) 21:29Z
fix/ekf2-agp-ctrl-bitmask 60e46f051a merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 21:32Z
fix/mag-inconsistency-nan 148d27271a merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 21:35Z
fix/loiter-to-alt-current-position aff6c3a28f merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 21:38Z
fix/vl53l1x-init-data-ready-timeout f0d3bdc1e4 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 21:42Z
fix/uavcan-param-count-width 7d84d5bed8 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 21:45Z
fix/tecs-load-factor-feedforward 1cf1177642 merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 21:48Z
fix/ekf2-sensor-enable-param-range bb5b4f481c merge=ok format=ok sitl=ok tests=ok allyes=ok v6x=ok 100% tests passed, 0 tests failed out of 215 21:51Z
LAB PASS7 DONE 21:51Z
Tests applied to main, then run on the branch (lab):
main=dbab213c34 16:38Z
29116 fix/collision-prevention-wrap-bin CollisionPrevention|ObstacleMath RED-on-main (0% tests passed, 2 tests failed out of 2) PASS-on-branch (100% tests passed, 0 tests failed out of 2)
29117 fix/rc-sumd-32-channels sitl-rc_tests RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29125 fix/ekf2-external-wind-nonfinite test_EKF_airspeed RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29130 fix/ca-count-clamp ActuatorEffectivenessCount RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29132 fix/tunes-rest-outputs Tunes RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29133 fix/gnss-required-count-clamp gnssRedundancyChecks RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29138 fix/loiter-to-alt-current-position test_mission_base|test_mission_feasibility_geofence RED-on-main (0% tests passed, 2 tests failed out of 2) PASS-on-branch (100% tests passed, 0 tests failed out of 2)
29141 fix/trajectory-acosf-clamp TrajectoryConstraints RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29142 fix/notch-filter-bandwidth-nyquist NotchFilter RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29149 fix/sbus-output-low-clamp SbusOutput PASS-on-main () PASS-on-branch ()
29159 fix/rtl-direct-mission-land-do-jump test_rtl_direct_mission_land RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
29165 fix/tecs-load-factor-feedforward TECS BUILD-FAIL-on-main: FAILED: src/lib/tecs/CMakeFiles/functional-TECS.dir/TECSTest.cpp.o
TOM3 DONE 17:05Z
main=95ede794c0 18:09Z
29143 fix/mag-inconsistency-nan VehicleMagnetometer RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
TOM3 DONE 18:10Z
main=95ede794c0 18:11Z
29165 fix/tecs-load-factor-feedforward TECS RED-on-main (0% tests passed, 1 tests failed out of 1) PASS-on-branch (100% tests passed, 0 tests failed out of 1)
TOM3 DONE 18:11Z
The two `allyes=FAIL` lines (17:02Z airframes, 17:10Z collision-prevention) are the first attempts, before the container had the `lark` module the IDL hash step imports and before the lab had a ccache stand-in for the idlc sub-build; the later lines for the same branches are the valid ones. Nothing else is red.
