PX4 Dev Call: Jul 29, 2026 (Team sync, and Community Q&A)
PX4 Sync / Q&A - 2026-07-29T15:00:00Z
This week: 42 PRs merged | 270 awaiting review | 0 new bugs
Announcements
Events
Dev Call Items
  • Fligh test team update
  • Release Discussion
  • Q&A
Release
Updates:
Issues:
Decisions:
PRs Merged This Week
42 PRs merged this week →
PRs Awaiting Review
270 PRs awaiting review →
New Bug Reports
  • No new bugs
Other New Issues
6 new issues →
Q&A
  1. The issue with XRCE-DDS: If Ethernet is up before DDS runs , all works ok. Otherwise, id the Ethernet or linux are not up then XRCE-DDs does not start. [Bug] UXRCE-DDS Client remains disconnected: does not attempt retries · Issue #27860 · PX4/PX4-Autopilot · GitHub
  2. If you run the rover , transitioning from stabilized/manual to position mode will get stalled in altitude mode (which does not make sense for a rover) doest not switch to the next mode which is position fixed and gets back to altitude mode. Relevant issue [Bug] Rover Failsafes into Altitude Mode (from Position) · Issue #28108 · PX4/PX4-Autopilot · GitHub
  3. fix(mc_pos_control): reject non-positive automatic vertical speed limits by JBotwina · Pull Request #28104 · PX4/PX4-Autopilot · GitHub : Adding many constraints would need a noticeable amount of code base change and adds many condiiton checks. For now the best is to rely on Metadata as a guide so the values are not chosen outside the value ranges.
  4. From @MaEtUgR PixRacer was flashed with the latest main and on the boot it goes out of ram . CC: @JulianOes
Action Items
