HI,
I am trying to build the PX4 fro Durandal usnig last release sourcecode. (I did build for other platforms wirthout problems)
During The building process of PX4 firmware for holybro durandal
make holybro_durandal-v1_default
you also build the bootloader_firmware.
then you get an error during the building step
*[1296/1320] Performing build step for ‘bootloader_firmware’
[16/257] Generating apps/libapps.a
FAILED: NuttX/apps/libapps.a
cd /cygdrive/c/PX4/home/PX4-Autopilot/build/holybro_durandal-v1_default/external/Build/bootloader_firmware/NuttX/apps && find /cygdrive/c/PX4/home/PX4-Autopilot/build/holybro_durandal-v1_default/external/Build/bootloader_firmware/NuttX/apps -name .o -delete && make --quiet --no-print-directory TOPDIR="/cygdrive/c/PX4/home/PX4-Autopilot/build/holybro_durandal-v1_default/external/Build/bootloader_firmware/NuttX/nuttx" > nuttx_apps.log
Assembler messages:
Fatal error: can’t create cdcacm_main.cygdrive.c.PX4.home.PX4-Autopilot.build.holybro_durandal-v1_default.external.Build.bootloader_firmware.NuttX.apps.system.cdcacm.o: No such file or directory
make[3]: *** [/cygdrive/c/PX4/home/PX4-Autopilot/build/holybro_durandal-v1_default/external/Build/bootloader_firmware/NuttX/apps/Application.mk:193 : cdcacm_main.cygdrive.c.PX4.home.PX4-Autopilot.build.holybro_durandal-v1_default.external.Build.bootloader_firmware.NuttX.apps.system.cdcacm.o] Erreur 1
make[2]: *** [Makefile:59 : /cygdrive/c/PX4/home/PX4-Autopilot/build/holybro_durandal-v1_default/external/Build/bootloader_firmware/NuttX/apps/system/cdcacm_all] Erreur 2
make[1]: *** [Makefile:53 : all] Erreur 2
[22/257] Generating nuttx/libs/libc/libc.a
At the opposite if you build the bootloader using the command :
make px4_fmu-v6x_bootloader
which is the same prcocess everything goes OK, there is no problem with libapps .
Can someone help ?
Thanks.
