Hi All,
This is my first build, and I’ve run into a roadblock I can’t seem to figure out. I have tested the ESCs on receiver pins and they all work, and I’ve confirmed with a multimeter that the 5v rail on the rear pins are powered from the BEC. I’ve tried moving through MOT_PWM_TYPE with Dshot300 and 600, then down to regular analog (0) and Oneshot125 (2). on analog and oneshot I tried to calibrate the ESCs, but when I power back up from the battery, the esc/motors just keep beeping at me (even after I press the red light/buzzer button on the GPS and it goes solid. I have my FRSKY X18 calibrated in radio calibration, and I’ve tried to adjust the trim above and below max on throttle before calibrating to make sure it’s sending a nice, strong max signal.
After a while of looking on here, Googling, and working with AI to troubleshoot, I’m stuck. I’ve given some information and my parameter configuration below and would greatly appreciate any help. Thanks in advance ![]()
Frame: Holybro x600
FC: Pixhawk 6X
ESC: Tekko32 F4 45A ESC with XT30 Plugs
Radio: Frsky TD x18 (Archer Plus R6 receiver in ACCESS mode)
Motors: Tmotor MN4014 KV330 Motor with XT30 Plug
Batt: 8000mah 26c 6S
ArduCopter V4.6.2 (1ebd4d99)
ACRO_BAL_PITCH,1
ACRO_BAL_ROLL,1
ACRO_OPTIONS,0
ACRO_RP_EXPO,0.3
ACRO_RP_RATE,360
ACRO_RP_RATE_TC,0
ACRO_THR_MID,0
ACRO_TRAINER,2
ACRO_Y_EXPO,0
ACRO_Y_RATE,202.5
ACRO_Y_RATE_TC,0
ADSB_TYPE,0
AHRS_COMP_BETA,0.1
AHRS_EKF_TYPE,3
AHRS_GPS_GAIN,1
AHRS_GPS_MINSATS,6
AHRS_GPS_USE,1
AHRS_OPTIONS,0
AHRS_ORIENTATION,0
AHRS_RP_P,0.2
AHRS_TRIM_X,0.01477038
AHRS_TRIM_Y,-0.001911775
AHRS_TRIM_Z,0
AHRS_WIND_MAX,0
AHRS_YAW_P,0.2
ANGLE_MAX,3000
ARMING_ACCTHRESH,0.75
ARMING_CHECK,1
ARMING_CRSDP_IGN,0
ARMING_MAGTHRESH,100
ARMING_MIS_ITEMS,0
ARMING_NEED_LOC,0
ARMING_OPTIONS,0
ARMING_RUDDER,2
ARSPD_ENABLE,0
ATC_ACCEL_P_MAX,110000
ATC_ACCEL_R_MAX,110000
ATC_ACCEL_Y_MAX,27000
ATC_ANG_LIM_TC,1
ATC_ANG_PIT_P,4.5
ATC_ANG_RLL_P,4.5
ATC_ANG_YAW_P,4.5
ATC_ANGLE_BOOST,1
ATC_INPUT_TC,0.15
ATC_LAND_P_MULT,1
ATC_LAND_R_MULT,1
ATC_LAND_Y_MULT,1
ATC_RAT_PIT_D,0.0036
ATC_RAT_PIT_D_FF,0
ATC_RAT_PIT_FF,0
ATC_RAT_PIT_FLTD,20
ATC_RAT_PIT_FLTE,0
ATC_RAT_PIT_FLTT,20
ATC_RAT_PIT_I,0.135
ATC_RAT_PIT_IMAX,0.5
ATC_RAT_PIT_NEF,0
ATC_RAT_PIT_NTF,0
ATC_RAT_PIT_P,0.135
ATC_RAT_PIT_PDMX,0
ATC_RAT_PIT_SMAX,0
ATC_RAT_RLL_D,0.0036
ATC_RAT_RLL_D_FF,0
ATC_RAT_RLL_FF,0
ATC_RAT_RLL_FLTD,20
ATC_RAT_RLL_FLTE,0
ATC_RAT_RLL_FLTT,20
ATC_RAT_RLL_I,0.135
ATC_RAT_RLL_IMAX,0.5
ATC_RAT_RLL_NEF,0
ATC_RAT_RLL_NTF,0
ATC_RAT_RLL_P,0.135
ATC_RAT_RLL_PDMX,0
ATC_RAT_RLL_SMAX,0
ATC_RAT_YAW_D,0
ATC_RAT_YAW_D_FF,0
ATC_RAT_YAW_FF,0
ATC_RAT_YAW_FLTD,20
ATC_RAT_YAW_FLTE,2.5
ATC_RAT_YAW_FLTT,20
ATC_RAT_YAW_I,0.018
ATC_RAT_YAW_IMAX,0.5
ATC_RAT_YAW_NEF,0
ATC_RAT_YAW_NTF,0
ATC_RAT_YAW_P,0.18
ATC_RAT_YAW_PDMX,0
ATC_RAT_YAW_SMAX,0
ATC_RATE_FF_ENAB,1
ATC_RATE_P_MAX,0
ATC_RATE_R_MAX,0
ATC_RATE_Y_MAX,0
ATC_SLEW_YAW,6000
ATC_THR_G_BOOST,0
ATC_THR_MIX_MAN,0.1
ATC_THR_MIX_MAX,0.5
ATC_THR_MIX_MIN,0.1
AUTO_OPTIONS,0
AUTOTUNE_AGGR,0.075
AUTOTUNE_AXES,7
AUTOTUNE_MIN_D,0.0005
AVD_ENABLE,0
AVOID_ACCEL_MAX,3
AVOID_ALT_MIN,0
AVOID_ANGLE_MAX,1000
AVOID_BACKUP_DZ,0.1
AVOID_BACKUP_SPD,0.75
AVOID_BACKZ_SPD,0.75
AVOID_BEHAVE,0
AVOID_DIST_MAX,5
AVOID_ENABLE,3
AVOID_MARGIN,2
BARO_ALT_OFFSET,0
BARO_ALTERR_MAX,2000
BARO_EXT_BUS,-1
BARO_FIELD_ELV,0
BARO_FLTR_RNG,0
BARO_GND_TEMP,0
BARO_OPTIONS,0
BARO_PRIMARY,0
BARO_PROBE_EXT,0
BARO1_DEVID,292369
BARO1_GND_PRESS,101172.3
BARO1_WCF_ENABLE,0
BARO2_DEVID,1074177
BARO2_GND_PRESS,100956.8
BARO2_WCF_ENABLE,0
BARO3_DEVID,0
BARO3_GND_PRESS,0
BARO3_WCF_ENABLE,0
BATT_ARM_MAH,0
BATT_ARM_VOLT,0
BATT_CAPACITY,8000
BATT_CRT_MAH,0
BATT_CRT_VOLT,0
BATT_FS_CRT_ACT,0
BATT_FS_LOW_ACT,0
BATT_FS_VOLTSRC,0
BATT_I2C_ADDR,69
BATT_I2C_BUS,1
BATT_LOW_MAH,0
BATT_LOW_TIMER,10
BATT_LOW_VOLT,10.5
BATT_MAX_AMPS,90
BATT_MONITOR,21
BATT_OPTIONS,0
BATT_SERIAL_NUM,-1
BATT_SHUNT,0.0005
BATT2_MONITOR,0
BATT3_MONITOR,0
BATT4_MONITOR,0
BATT5_MONITOR,0
BATT6_MONITOR,0
BATT7_MONITOR,0
BATT8_MONITOR,0
BATT9_MONITOR,0
BCN_TYPE,0
BRD_BOOT_DELAY,0
BRD_HEAT_I,0.07
BRD_HEAT_IMAX,70
BRD_HEAT_LOWMGN,0
BRD_HEAT_P,50
BRD_HEAT_TARG,45
BRD_IO_DSHOT,0
BRD_IO_ENABLE,1
BRD_OPTIONS,1
BRD_RTC_TYPES,1
BRD_RTC_TZ_MIN,0
BRD_SAFETY_DEFLT,1
BRD_SAFETY_MASK,16368
BRD_SAFETYOPTION,3
BRD_SBUS_OUT,0
BRD_SD_FENCE,0
BRD_SD_MISSION,0
BRD_SD_SLOWDOWN,0
BRD_SER1_RTSCTS,2
BRD_SER2_RTSCTS,2
BRD_SER5_RTSCTS,2
BRD_SERIAL_NUM,0
BRD_TYPE,43
BRD_VBUS_MIN,4.3
BRD_VSERVO_MIN,0
BTN_ENABLE,0
CAM_AUTO_ONLY,0
CAM_MAX_ROLL,0
CAM_RC_TYPE,0
CAM1_TYPE,0
CAM2_TYPE,0
CAN_D1_PROTOCOL,1
CAN_D1_PROTOCOL2,0
CAN_D2_PROTOCOL,1
CAN_D2_PROTOCOL2,0
CAN_LOGLEVEL,0
CAN_P1_DRIVER,0
CAN_P2_DRIVER,0
CAN_SLCAN_CPORT,0
CAN_SLCAN_SDELAY,1
CAN_SLCAN_SERNUM,-1
CAN_SLCAN_TIMOUT,0
CHUTE_ENABLED,0
CIRCLE_OPTIONS,1
CIRCLE_RADIUS,1000
CIRCLE_RATE,20
COMPASS_AUTO_ROT,2
COMPASS_AUTODEC,1
COMPASS_CAL_FIT,16
COMPASS_DEC,0
COMPASS_DEV_ID,658953
COMPASS_DEV_ID2,0
COMPASS_DEV_ID3,0
COMPASS_DEV_ID4,0
COMPASS_DEV_ID5,0
COMPASS_DEV_ID6,0
COMPASS_DEV_ID7,0
COMPASS_DEV_ID8,0
COMPASS_DIA_X,1.011768
COMPASS_DIA_Y,0.9756986
COMPASS_DIA_Z,1.033824
COMPASS_DIA2_X,1
COMPASS_DIA2_Y,1
COMPASS_DIA2_Z,1
COMPASS_DIA3_X,1
COMPASS_DIA3_Y,1
COMPASS_DIA3_Z,1
COMPASS_DISBLMSK,0
COMPASS_ENABLE,1
COMPASS_EXTERN2,0
COMPASS_EXTERN3,0
COMPASS_EXTERNAL,0
COMPASS_FLTR_RNG,0
COMPASS_LEARN,0
COMPASS_MOT_X,0
COMPASS_MOT_Y,0
COMPASS_MOT_Z,0
COMPASS_MOT2_X,0
COMPASS_MOT2_Y,0
COMPASS_MOT2_Z,0
COMPASS_MOT3_X,0
COMPASS_MOT3_Y,0
COMPASS_MOT3_Z,0
COMPASS_MOTCT,0
COMPASS_ODI_X,0.01520998
COMPASS_ODI_Y,-0.01835874
COMPASS_ODI_Z,-0.08106688
COMPASS_ODI2_X,0
COMPASS_ODI2_Y,0
COMPASS_ODI2_Z,0
COMPASS_ODI3_X,0
COMPASS_ODI3_Y,0
COMPASS_ODI3_Z,0
COMPASS_OFFS_MAX,1800
COMPASS_OFS_X,9.654062
COMPASS_OFS_Y,24.20154
COMPASS_OFS_Z,33.69741
COMPASS_OFS2_X,0
COMPASS_OFS2_Y,0
COMPASS_OFS2_Z,0
COMPASS_OFS3_X,0
COMPASS_OFS3_Y,0
COMPASS_OFS3_Z,0
COMPASS_OPTIONS,0
COMPASS_ORIENT,6
COMPASS_ORIENT2,0
COMPASS_ORIENT3,0
COMPASS_PMOT_EN,0
COMPASS_PRIO1_ID,658953
COMPASS_PRIO2_ID,331777
COMPASS_PRIO3_ID,0
COMPASS_SCALE,1.012689
COMPASS_SCALE2,0
COMPASS_SCALE3,0
COMPASS_USE,1
COMPASS_USE2,0
COMPASS_USE3,0
CUST_ROT_ENABLE,0
DEV_OPTIONS,0
DISARM_DELAY,10
EAHRS_TYPE,0
EFI_TYPE,0
EK3_ABIAS_P_NSE,0.02
EK3_ACC_BIAS_LIM,1
EK3_ACC_P_NSE,0.35
EK3_AFFINITY,0
EK3_ALT_M_NSE,2
EK3_BCN_DELAY,50
EK3_BCN_I_GTE,500
EK3_BCN_M_NSE,1
EK3_BETA_MASK,0
EK3_CHECK_SCALE,100
EK3_DRAG_BCOEF_X,0
EK3_DRAG_BCOEF_Y,0
EK3_DRAG_M_NSE,0.5
EK3_DRAG_MCOEF,0
EK3_EAS_I_GATE,400
EK3_EAS_M_NSE,1.4
EK3_ENABLE,1
EK3_ERR_THRESH,0.2
EK3_FLOW_DELAY,10
EK3_FLOW_I_GATE,300
EK3_FLOW_M_NSE,0.25
EK3_FLOW_USE,1
EK3_GBIAS_P_NSE,0.001
EK3_GLITCH_RAD,25
EK3_GND_EFF_DZ,4
EK3_GPS_CHECK,31
EK3_GPS_VACC_MAX,0
EK3_GSF_RST_MAX,2
EK3_GSF_RUN_MASK,3
EK3_GSF_USE_MASK,3
EK3_GYRO_P_NSE,0.015
EK3_HGT_DELAY,60
EK3_HGT_I_GATE,500
EK3_HRT_FILT,2
EK3_IMU_MASK,3
EK3_LOG_LEVEL,0
EK3_MAG_CAL,3
EK3_MAG_EF_LIM,50
EK3_MAG_I_GATE,300
EK3_MAG_M_NSE,0.05
EK3_MAG_MASK,0
EK3_MAGB_P_NSE,0.0001
EK3_MAGE_P_NSE,0.001
EK3_MAX_FLOW,2.5
EK3_NOAID_M_NSE,10
EK3_OGN_HGT_MASK,0
EK3_OGNM_TEST_SF,2
EK3_OPTIONS,0
EK3_POS_I_GATE,500
EK3_POSNE_M_NSE,0.5
EK3_PRIMARY,0
EK3_RNG_I_GATE,500
EK3_RNG_M_NSE,0.5
EK3_RNG_USE_HGT,-1
EK3_RNG_USE_SPD,2
EK3_SRC_OPTIONS,1
EK3_SRC1_POSXY,3
EK3_SRC1_POSZ,1
EK3_SRC1_VELXY,3
EK3_SRC1_VELZ,3
EK3_SRC1_YAW,1
EK3_SRC2_POSXY,0
EK3_SRC2_POSZ,1
EK3_SRC2_VELXY,0
EK3_SRC2_VELZ,0
EK3_SRC2_YAW,0
EK3_SRC3_POSXY,0
EK3_SRC3_POSZ,1
EK3_SRC3_VELXY,0
EK3_SRC3_VELZ,0
EK3_SRC3_YAW,0
EK3_TAU_OUTPUT,25
EK3_TERR_GRAD,0.1
EK3_VEL_I_GATE,500
EK3_VELD_M_NSE,0.5
EK3_VELNE_M_NSE,0.3
EK3_VIS_VERR_MAX,0.9
EK3_VIS_VERR_MIN,0.1
EK3_WENC_VERR,0.1
EK3_WIND_P_NSE,0.2
EK3_WIND_PSCALE,1
EK3_YAW_I_GATE,300
EK3_YAW_M_NSE,0.5
ESC_CALIBRATION,1
ESC_TLM_MAV_OFS,0
FENCE_ACTION,1
FENCE_ALT_MAX,100
FENCE_ALT_MIN,-10
FENCE_AUTOENABLE,0
FENCE_ENABLE,0
FENCE_MARGIN,2
FENCE_OPTIONS,0
FENCE_RADIUS,300
FENCE_TOTAL,0
FENCE_TYPE,7
FFT_ENABLE,0
FHLD_BRAKE_RATE,8
FHLD_FILT_HZ,5
FHLD_FLOW_MAX,0.6
FHLD_QUAL_MIN,10
FHLD_XY_FILT_HZ,5
FHLD_XY_I,0.3
FHLD_XY_IMAX,3000
FHLD_XY_P,0.2
FILT1_TYPE,0
FILT2_TYPE,0
FILT3_TYPE,0
FILT4_TYPE,0
FILT5_TYPE,0
FILT6_TYPE,0
FILT7_TYPE,0
FILT8_TYPE,0
FLIGHT_OPTIONS,0
FLOW_TYPE,0
FLTMODE_CH,6
FLTMODE_GCSBLOCK,0
FLTMODE1,0
FLTMODE2,0
FLTMODE3,0
FLTMODE4,0
FLTMODE5,0
FLTMODE6,6
FOLL_ENABLE,0
FORMAT_VERSION,120
FRAME_CLASS,1
FRAME_TYPE,1
FRSKY_DNLINK_ID,27
FRSKY_DNLINK1_ID,20
FRSKY_DNLINK2_ID,7
FRSKY_OPTIONS,0
FRSKY_UPLINK_ID,13
FS_CRASH_CHECK,1
FS_DR_ENABLE,2
FS_DR_TIMEOUT,30
FS_EKF_ACTION,1
FS_EKF_FILT,5
FS_EKF_THRESH,0.8
FS_GCS_ENABLE,0
FS_GCS_TIMEOUT,5
FS_OPTIONS,16
FS_THR_ENABLE,1
FS_THR_VALUE,975
FS_VIBE_ENABLE,1
GCS_PID_MASK,0
GEN_TYPE,0
GND_EFFECT_COMP,1
GPS_AUTO_CONFIG,1
GPS_AUTO_SWITCH,1
GPS_BLEND_MASK,5
GPS_DRV_OPTIONS,0
GPS_HDOP_GOOD,140
GPS_INJECT_TO,127
GPS_MIN_ELEV,-100
GPS_NAVFILTER,8
GPS_PRIMARY,0
GPS_RAW_DATA,0
GPS_SAVE_CFG,2
GPS_SBAS_MODE,2
GPS_SBP_LOGMASK,-256
GPS1_TYPE,0
GPS2_TYPE,0
GRIP_ENABLE,0
GUID_OPTIONS,0
GUID_TIMEOUT,3
INITIAL_MODE,0
INS_ACC_BODYFIX,2
INS_ACC_ID,3866898
INS_ACC1_CALTEMP,44.1875
INS_ACC2_CALTEMP,44.125
INS_ACC2_ID,3866906
INS_ACC2OFFS_X,-0.06895342
INS_ACC2OFFS_Y,0.06349473
INS_ACC2OFFS_Z,-0.03981328
INS_ACC2SCAL_X,0.997826
INS_ACC2SCAL_Y,0.9975964
INS_ACC2SCAL_Z,0.9990478
INS_ACC3_CALTEMP,38.1875
INS_ACC3_ID,3866890
INS_ACC3OFFS_X,0.0332566
INS_ACC3OFFS_Y,-0.05412593
INS_ACC3OFFS_Z,-0.01675882
INS_ACC3SCAL_X,0.9992859
INS_ACC3SCAL_Y,1.000224
INS_ACC3SCAL_Z,0.9994385
INS_ACCEL_FILTER,20
INS_ACCOFFS_X,-0.04853185
INS_ACCOFFS_Y,0.01694644
INS_ACCOFFS_Z,0.0421691
INS_ACCSCAL_X,0.9997257
INS_ACCSCAL_Y,0.9996889
INS_ACCSCAL_Z,0.9997129
INS_ENABLE_MASK,127
INS_FAST_SAMPLE,7
INS_GYR_CAL,1
INS_GYR_ID,3866898
INS_GYR1_CALTEMP,33.09375
INS_GYR2_CALTEMP,32.84375
INS_GYR2_ID,3866906
INS_GYR2OFFS_X,-0.003785366
INS_GYR2OFFS_Y,0.002423363
INS_GYR2OFFS_Z,0.0001334808
INS_GYR3_CALTEMP,32.34375
INS_GYR3_ID,3866890
INS_GYR3OFFS_X,-0.0004197803
INS_GYR3OFFS_Y,0.007158108
INS_GYR3OFFS_Z,-0.0001076297
INS_GYRO_FILTER,20
INS_GYRO_RATE,1
INS_GYROFFS_X,0.0006140069
INS_GYROFFS_Y,0.001204115
INS_GYROFFS_Z,-0.0004315301
INS_HNTC2_ENABLE,0
INS_HNTCH_ENABLE,0
INS_LOG_BAT_CNT,1024
INS_LOG_BAT_LGCT,32
INS_LOG_BAT_LGIN,20
INS_LOG_BAT_MASK,0
INS_LOG_BAT_OPT,0
INS_POS1_X,0
INS_POS1_Y,0
INS_POS1_Z,0
INS_POS2_X,0
INS_POS2_Y,0
INS_POS2_Z,0
INS_POS3_X,0
INS_POS3_Y,0
INS_POS3_Z,0
INS_RAW_LOG_OPT,0
INS_STILL_THRESH,2.5
INS_TCAL_OPTIONS,0
INS_TCAL1_ENABLE,0
INS_TCAL2_ENABLE,0
INS_TCAL3_ENABLE,0
INS_TRIM_OPTION,1
INS_USE,1
INS_USE2,1
INS_USE3,1
KDE_NPOLE,14
LAND_ALT_LOW,1000
LAND_REPOSITION,1
LAND_SPEED,50
LAND_SPEED_HIGH,0
LGR_ENABLE,0
LOG_BACKEND_TYPE,1
LOG_BITMASK,180222
LOG_DARM_RATEMAX,0
LOG_DISARMED,0
LOG_FILE_BUFSIZE,200
LOG_FILE_DSRMROT,0
LOG_FILE_MB_FREE,500
LOG_FILE_RATEMAX,0
LOG_FILE_TIMEOUT,5
LOG_MAV_BUFSIZE,8
LOG_MAV_RATEMAX,0
LOG_MAX_FILES,500
LOG_REPLAY,0
LOIT_ACC_MAX,500
LOIT_ANG_MAX,0
LOIT_BRK_ACCEL,250
LOIT_BRK_DELAY,1
LOIT_BRK_JERK,500
LOIT_SPEED,1250
MIS_OPTIONS,0
MIS_RESTART,0
MIS_TOTAL,0
MNT1_TYPE,0
MNT2_TYPE,0
MOT_BAT_CURR_MAX,0
MOT_BAT_CURR_TC,5
MOT_BAT_IDX,0
MOT_BAT_VOLT_MAX,0
MOT_BAT_VOLT_MIN,0
MOT_BOOST_SCALE,0
MOT_HOVER_LEARN,2
MOT_OPTIONS,0
MOT_PWM_MAX,2000
MOT_PWM_MIN,1000
MOT_PWM_TYPE,2
MOT_SAFE_DISARM,0
MOT_SAFE_TIME,1
MOT_SLEW_DN_TIME,0
MOT_SLEW_UP_TIME,0
MOT_SPIN_ARM,0.1
MOT_SPIN_MAX,0.95
MOT_SPIN_MIN,0.15
MOT_SPOOL_TIM_DN,0
MOT_SPOOL_TIME,0.5
MOT_THST_EXPO,0.65
MOT_THST_HOVER,0.35
MOT_YAW_HEADROOM,200
MSP_OPTIONS,0
MSP_OSD_NCELLS,0
NET_ENABLE,0
NET_P1_TYPE,0
NET_P2_TYPE,0
NET_P3_TYPE,0
NET_P4_TYPE,0
NMEA_MSG_EN,3
NMEA_RATE_MS,100
NTF_BUZZ_ON_LVL,1
NTF_BUZZ_PIN,-1
NTF_BUZZ_TYPES,5
NTF_BUZZ_VOLUME,100
NTF_DISPLAY_TYPE,0
NTF_LED_BRIGHT,3
NTF_LED_LEN,1
NTF_LED_OVERRIDE,0
NTF_LED_TYPES,123079
OA_TYPE,0
OSD_TYPE,0
PHLD_BRAKE_ANGLE,3000
PHLD_BRAKE_RATE,8
PILOT_ACCEL_Z,250
PILOT_SPEED_DN,0
PILOT_SPEED_UP,250
PILOT_THR_BHV,0
PILOT_THR_FILT,0
PILOT_TKOFF_ALT,0
PILOT_Y_EXPO,0
PILOT_Y_RATE,202.5
PILOT_Y_RATE_TC,0
PLDP_DELAY,0
PLDP_RNG_MAX,0
PLDP_SPEED_DN,0
PLDP_THRESH,0.9
PLND_ENABLED,0
PRX_ALT_MIN,1
PRX_FILT,0.25
PRX_IGN_GND,0
PRX_LOG_RAW,0
PRX1_TYPE,0
PRX2_TYPE,0
PRX3_TYPE,0
PRX4_TYPE,0
PRX5_TYPE,0
PSC_ACCZ_D,0
PSC_ACCZ_D_FF,0
PSC_ACCZ_FF,0
PSC_ACCZ_FLTD,0
PSC_ACCZ_FLTE,20
PSC_ACCZ_FLTT,0
PSC_ACCZ_I,1
PSC_ACCZ_IMAX,800
PSC_ACCZ_NEF,0
PSC_ACCZ_NTF,0
PSC_ACCZ_P,0.5
PSC_ACCZ_PDMX,0
PSC_ACCZ_SMAX,0
PSC_ANGLE_MAX,0
PSC_JERK_XY,5
PSC_JERK_Z,5
PSC_POSXY_P,1
PSC_POSZ_P,1
PSC_VELXY_D,0.25
PSC_VELXY_FF,0
PSC_VELXY_FLTD,5
PSC_VELXY_FLTE,5
PSC_VELXY_I,1
PSC_VELXY_IMAX,1000
PSC_VELXY_P,2
PSC_VELZ_D,0
PSC_VELZ_FF,0
PSC_VELZ_FLTD,5
PSC_VELZ_FLTE,5
PSC_VELZ_I,0
PSC_VELZ_IMAX,1000
PSC_VELZ_P,5
RALLY_INCL_HOME,1
RALLY_LIMIT_KM,0.3
RALLY_TOTAL,0
RC_FS_TIMEOUT,1
RC_OPTIONS,32
RC_OVERRIDE_TIME,3
RC_PROTOCOLS,1
RC_SPEED,490
RC1_DZ,20
RC1_MAX,2006
RC1_MIN,982
RC1_OPTION,0
RC1_REVERSED,0
RC1_TRIM,1495
RC10_DZ,0
RC10_MAX,1900
RC10_MIN,1100
RC10_OPTION,0
RC10_REVERSED,0
RC10_TRIM,1500
RC11_DZ,0
RC11_MAX,1900
RC11_MIN,1100
RC11_OPTION,0
RC11_REVERSED,0
RC11_TRIM,1500
RC12_DZ,0
RC12_MAX,1900
RC12_MIN,1100
RC12_OPTION,0
RC12_REVERSED,0
RC12_TRIM,1500
RC13_DZ,0
RC13_MAX,1900
RC13_MIN,1100
RC13_OPTION,0
RC13_REVERSED,0
RC13_TRIM,1500
RC14_DZ,0
RC14_MAX,1900
RC14_MIN,1100
RC14_OPTION,0
RC14_REVERSED,0
RC14_TRIM,1500
RC15_DZ,0
RC15_MAX,1900
RC15_MIN,1100
RC15_OPTION,0
RC15_REVERSED,0
RC15_TRIM,1500
RC16_DZ,0
RC16_MAX,1900
RC16_MIN,1100
RC16_OPTION,0
RC16_REVERSED,0
RC16_TRIM,1500
RC2_DZ,20
RC2_MAX,2006
RC2_MIN,982
RC2_OPTION,0
RC2_REVERSED,0
RC2_TRIM,1495
RC3_DZ,30
RC3_MAX,2006
RC3_MIN,982
RC3_OPTION,0
RC3_REVERSED,0
RC3_TRIM,1525
RC4_DZ,20
RC4_MAX,2006
RC4_MIN,982
RC4_OPTION,0
RC4_REVERSED,0
RC4_TRIM,1495
RC5_DZ,0
RC5_MAX,2006
RC5_MIN,982
RC5_OPTION,153
RC5_REVERSED,0
RC5_TRIM,982
RC6_DZ,0
RC6_MAX,2006
RC6_MIN,982
RC6_OPTION,0
RC6_REVERSED,0
RC6_TRIM,982
RC7_DZ,0
RC7_MAX,2006
RC7_MIN,982
RC7_OPTION,0
RC7_REVERSED,0
RC7_TRIM,1495
RC8_DZ,0
RC8_MAX,2006
RC8_MIN,982
RC8_OPTION,0
RC8_REVERSED,0
RC8_TRIM,1495
RC9_DZ,0
RC9_MAX,1900
RC9_MIN,1100
RC9_OPTION,0
RC9_REVERSED,0
RC9_TRIM,1500
RCMAP_PITCH,2
RCMAP_ROLL,1
RCMAP_THROTTLE,3
RCMAP_YAW,4
RELAY1_FUNCTION,0
RELAY2_FUNCTION,0
RELAY3_FUNCTION,0
RELAY4_FUNCTION,0
RELAY5_FUNCTION,0
RELAY6_FUNCTION,0
RNGFND_FILT,0.5
RNGFND1_TYPE,0
RNGFND2_TYPE,0
RNGFND3_TYPE,0
RNGFND4_TYPE,0
RNGFND5_TYPE,0
RNGFND6_TYPE,0
RNGFND7_TYPE,0
RNGFND8_TYPE,0
RNGFND9_TYPE,0
RNGFNDA_TYPE,0
RPM1_TYPE,0
RPM2_TYPE,0
RSSI_ANA_PIN,-1
RSSI_CHAN_HIGH,2000
RSSI_CHAN_LOW,1000
RSSI_CHANNEL,0
RSSI_PIN_HIGH,5
RSSI_PIN_LOW,0
RSSI_TYPE,3
RTL_ALT,1500
RTL_ALT_FINAL,0
RTL_ALT_TYPE,0
RTL_CLIMB_MIN,0
RTL_CONE_SLOPE,3
RTL_LOIT_TIME,5000
RTL_OPTIONS,0
RTL_SPEED,0
SCHED_DEBUG,0
SCHED_LOOP_RATE,400
SCHED_OPTIONS,0
SCR_ENABLE,0
SERIAL_PASS1,0
SERIAL_PASS2,-1
SERIAL_PASSTIMO,15
SERIAL0_BAUD,115
SERIAL0_PROTOCOL,2
SERIAL1_BAUD,57
SERIAL1_OPTIONS,0
SERIAL1_PROTOCOL,2
SERIAL2_BAUD,100
SERIAL2_OPTIONS,7
SERIAL2_PROTOCOL,15
SERIAL3_BAUD,230
SERIAL3_OPTIONS,0
SERIAL3_PROTOCOL,5
SERIAL4_BAUD,230
SERIAL4_OPTIONS,0
SERIAL4_PROTOCOL,5
SERIAL5_BAUD,57
SERIAL5_OPTIONS,0
SERIAL5_PROTOCOL,-1
SERIAL6_BAUD,57
SERIAL6_OPTIONS,0
SERIAL6_PROTOCOL,-1
SERIAL7_BAUD,57
SERIAL7_OPTIONS,0
SERIAL7_PROTOCOL,-1
SERIAL8_BAUD,115200
SERIAL8_OPTIONS,0
SERIAL8_PROTOCOL,2
SERVO_32_ENABLE,0
SERVO_BLH_3DMASK,0
SERVO_BLH_AUTO,0
SERVO_BLH_BDMASK,0
SERVO_BLH_DEBUG,0
SERVO_BLH_MASK,0
SERVO_BLH_OTYPE,0
SERVO_BLH_POLES,14
SERVO_BLH_PORT,0
SERVO_BLH_RVMASK,0
SERVO_BLH_TEST,0
SERVO_BLH_TMOUT,0
SERVO_BLH_TRATE,10
SERVO_DSHOT_ESC,0
SERVO_DSHOT_RATE,0
SERVO_FTW_MASK,0
SERVO_FTW_POLES,14
SERVO_FTW_RVMASK,0
SERVO_GPIO_MASK,0
SERVO_RATE,50
SERVO_RC_FS_MSK,0
SERVO_ROB_POSMAX,4095
SERVO_ROB_POSMIN,0
SERVO_SBUS_RATE,50
SERVO_VOLZ_MASK,0
SERVO_VOLZ_RANGE,200
SERVO1_FUNCTION,33
SERVO1_MAX,1900
SERVO1_MIN,1100
SERVO1_REVERSED,0
SERVO1_TRIM,1500
SERVO10_FUNCTION,0
SERVO10_MAX,1900
SERVO10_MIN,1100
SERVO10_REVERSED,0
SERVO10_TRIM,1500
SERVO11_FUNCTION,0
SERVO11_MAX,1900
SERVO11_MIN,1100
SERVO11_REVERSED,0
SERVO11_TRIM,1500
SERVO12_FUNCTION,0
SERVO12_MAX,1900
SERVO12_MIN,1100
SERVO12_REVERSED,0
SERVO12_TRIM,1500
SERVO13_FUNCTION,0
SERVO13_MAX,1900
SERVO13_MIN,1100
SERVO13_REVERSED,0
SERVO13_TRIM,1500
SERVO14_FUNCTION,0
SERVO14_MAX,1900
SERVO14_MIN,1100
SERVO14_REVERSED,0
SERVO14_TRIM,1500
SERVO15_FUNCTION,0
SERVO15_MAX,1900
SERVO15_MIN,1100
SERVO15_REVERSED,0
SERVO15_TRIM,1500
SERVO16_FUNCTION,0
SERVO16_MAX,1900
SERVO16_MIN,1100
SERVO16_REVERSED,0
SERVO16_TRIM,1500
SERVO2_FUNCTION,34
SERVO2_MAX,1900
SERVO2_MIN,1100
SERVO2_REVERSED,0
SERVO2_TRIM,1500
SERVO3_FUNCTION,35
SERVO3_MAX,1900
SERVO3_MIN,1100
SERVO3_REVERSED,0
SERVO3_TRIM,1500
SERVO4_FUNCTION,36
SERVO4_MAX,1900
SERVO4_MIN,1100
SERVO4_REVERSED,0
SERVO4_TRIM,1500
SERVO5_FUNCTION,0
SERVO5_MAX,1900
SERVO5_MIN,1100
SERVO5_REVERSED,0
SERVO5_TRIM,1500
SERVO6_FUNCTION,0
SERVO6_MAX,1900
SERVO6_MIN,1100
SERVO6_REVERSED,0
SERVO6_TRIM,1500
SERVO7_FUNCTION,0
SERVO7_MAX,1900
SERVO7_MIN,1100
SERVO7_REVERSED,0
SERVO7_TRIM,1500
SERVO8_FUNCTION,0
SERVO8_MAX,1900
SERVO8_MIN,1100
SERVO8_REVERSED,0
SERVO8_TRIM,1500
SERVO9_FUNCTION,0
SERVO9_MAX,1900
SERVO9_MIN,1100
SERVO9_REVERSED,0
SERVO9_TRIM,1500
SID_AXIS,0
SIMPLE,0
SPRAY_ENABLE,0
SR0_ADSB,0
SR0_EXT_STAT,2
SR0_EXTRA1,4
SR0_EXTRA2,4
SR0_EXTRA3,2
SR0_PARAMS,0
SR0_POSITION,2
SR0_RAW_CTRL,0
SR0_RAW_SENS,2
SR0_RC_CHAN,2
SR1_ADSB,0
SR1_EXT_STAT,0
SR1_EXTRA1,0
SR1_EXTRA2,0
SR1_EXTRA3,0
SR1_PARAMS,0
SR1_POSITION,0
SR1_RAW_CTRL,0
SR1_RAW_SENS,0
SR1_RC_CHAN,0
SR2_ADSB,0
SR2_EXT_STAT,0
SR2_EXTRA1,0
SR2_EXTRA2,0
SR2_EXTRA3,0
SR2_PARAMS,0
SR2_POSITION,0
SR2_RAW_CTRL,0
SR2_RAW_SENS,0
SR2_RC_CHAN,0
SR3_ADSB,0
SR3_EXT_STAT,0
SR3_EXTRA1,0
SR3_EXTRA2,0
SR3_EXTRA3,0
SR3_PARAMS,0
SR3_POSITION,0
SR3_RAW_CTRL,0
SR3_RAW_SENS,0
SR3_RC_CHAN,0
SR4_ADSB,0
SR4_EXT_STAT,0
SR4_EXTRA1,0
SR4_EXTRA2,0
SR4_EXTRA3,0
SR4_PARAMS,0
SR4_POSITION,0
SR4_RAW_CTRL,0
SR4_RAW_SENS,0
SR4_RC_CHAN,0
SR5_ADSB,0
SR5_EXT_STAT,0
SR5_EXTRA1,0
SR5_EXTRA2,0
SR5_EXTRA3,0
SR5_PARAMS,0
SR5_POSITION,0
SR5_RAW_CTRL,0
SR5_RAW_SENS,0
SR5_RC_CHAN,0
SR6_ADSB,0
SR6_EXT_STAT,0
SR6_EXTRA1,0
SR6_EXTRA2,0
SR6_EXTRA3,0
SR6_PARAMS,0
SR6_POSITION,0
SR6_RAW_CTRL,0
SR6_RAW_SENS,0
SR6_RC_CHAN,0
SRTL_ACCURACY,2
SRTL_OPTIONS,0
SRTL_POINTS,300
STAT_BOOTCNT,131
STAT_FLTTIME,0
STAT_RESET,1
STAT_RUNTIME,34034
SUPER_SIMPLE,0
SURFTRAK_MODE,1
SURFTRAK_TC,1
SYSID_ENFORCE,0
SYSID_MYGCS,255
SYSID_THISMAV,1
TCAL_ENABLED,0
TELEM_DELAY,0
TERRAIN_CACHE_SZ,12
TERRAIN_ENABLE,1
TERRAIN_MARGIN,0.05
TERRAIN_OFS_MAX,30
TERRAIN_OPTIONS,0
TERRAIN_SPACING,100
THR_DZ,100
THROW_ALT_MAX,0
THROW_ALT_MIN,0
THROW_MOT_START,0
THROW_NEXTMODE,18
THROW_TYPE,0
TKOFF_RPM_MAX,0
TKOFF_RPM_MIN,0
TKOFF_SLEW_TIME,2
TKOFF_THR_MAX,0.9
TUNE,0
TUNE_MAX,0
TUNE_MIN,0
VISO_TYPE,0
VTX_ENABLE,0
WINCH_TYPE,0
WP_NAVALT_MIN,0
WP_YAW_BEHAVIOR,2
WPNAV_ACCEL,250
WPNAV_ACCEL_C,0
WPNAV_ACCEL_Z,100
WPNAV_JERK,1
WPNAV_RADIUS,200
WPNAV_RFND_USE,1
WPNAV_SPEED,1000
WPNAV_SPEED_DN,150
WPNAV_SPEED_UP,250
WPNAV_TER_MARGIN,10
WVANE_ENABLE,0
ZIGZ_AUTO_ENABLE,0
