Hi Jeff,
Welcome to the PX4 community!
The information you provided is useful, particularly the brick_valid = 0 indication and the approximately 4.9–5.0 V reading.
One important distinction is that a valid 5 V supply voltage does not necessarily mean PX4 recognizes the power module as a valid power source.
I would suggest checking a few things before assuming this is a firmware issue.
1. Power module compatibility
Can you confirm the exact manufacturer and model of your Pixhawk 2.4.8 B-Cube?
Some Pixhawk 2.4.8 variants have differences in their power input circuitry and connector wiring.
Please also confirm that the Holybro PM02 V3 pinout matches the flight controller’s POWER connector.
2. Power status
With the propellers removed and the flight controller powered from the battery through the power module, could you share the complete system_power topic output?
In the QGroundControl MAVLink Console, try:
listener system_power
This should help us determine whether the issue is related to power validity detection or the redundancy check.
3. Compare both power modules
Since you have two power modules available, it would be useful to compare the system_power output with each module.
Please keep the rest of the configuration unchanged between tests.
4. Check the warning conditions
Does the warning appear:
If the same behavior occurs on both controllers with both power modules, we should investigate the board-specific power detection configuration and firmware behavior.
5. Firmware and hardware identification
Please share the exact board identification reported by PX4, along with the complete startup warning.
I would avoid modifying power-validity thresholds or bypassing the redundancy checks until we understand why the power source is being reported as invalid.
Also, please keep the propellers removed during troubleshooting and avoid flight until the power system has been verified.
With the system_power output and exact hardware details, we should be able to narrow this down considerably.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
