Have a ROS base flight management system which manage dynamically the flight plan of a e-glider.
While most of the flight is done in the mission execution mode (following waypoints) at some point I would like to send specific bank commands while the pitch and throttle remains under the autopilot control to maintain the desired altitude & airspeed. Is it possible to do it through MAVROS? If not what you I need to do.
Thanks
