If you don’t get /local_pointcloud then your system is not running correctly. There are a couple of things you should check:
If you run rostopic hz on a camera topic: Do you see messages? Is your camera running?
If you set the rosconsole level to DEBUG (in the file /avoidance/local_planner/resource/custom_rosconsole.conf) and then run roslaunch, what output do you get?
In the launch file: Is the fcu_url set to the correct port for your device?
I am really sorry, I am not able to know that what should I do?
Please help me with the following problems regarding the questions above?
I have tested my camera is is working fine, but I am confused on which camera topic I have to do rostopic hz
I am attaching my custom_rosconsole.conf file in this there is only one line written, what should I change? custom_rosconsole.pdf (29.4 KB)
-I am also attaching my ports information and my launch file , I was not able to figure out that which port is my device connected. aero_launch_file.pdf (42.6 KB)
ports_info.pdf (39.1 KB)(This port information is from my drone not after ssh connection, but my drone is connected to the intel aero hotspot)
Just now I have noticed that all the pdf files that I uploaded isn’t working, so Ihave changed all the files and now they are opening easily.
So again, I am
attaching the output file of the command roslaunch local_planner local_planner_aero.launch, so that you can check that atleast this command is working fine or not. Output_File.pdf (74.2 KB)
I already told you what you have to do to debug your system. The problem is not that the script does not work but that you did not set up your system correctly. Please follow the steps I gave you:
Do rostopic list, you’ll see some topics named camera something. Do rostopic hz or echo on them to see whether they are published correctly. Only if you do that you will know if your camera is running correctly.
I don’t know how to explain that step any better. I think you can figure out that one
You need to figure out on what device your pixhawk “talks”. You can list all devices with “ls /dev” and then you need to put the right one in the launch file under “fcu_url”. But this is device specific. If you use mavlink router than the ports in the launch file must match the ports specified in the /etc/mavlink-router/main.conf
I have checked the rostopic hz and rostopic echo on my camera topics they are working fine, I am getting output from these camra topics.
I have set the rosconsole level to DEBUG than I run the command roslaunch local_planner local_planner_aero.launch than I have got the same output as before I am getting.
But I tried that rostopic hz on local pointcloud it is still not working.
nice, so now we’ve narrowed down the problem: It lies with near certainty in the communication with the pixhawk. The local planner is not getting the pose information from mavros. You can fix this by putting the correct fcu_url in the launch file
@Utkarsh_Goyal This is the wrong thread for this kind of discussion.
The output you posted does not give any information, we need to see the output of your roslaunch local_planner local_planner_aero.launch with the rosconsole level to debug in order to tell you anything useful
Sorry I was not aware that I should not discuss on this thread.
So can you please tell me which will be better for discussion, as I am new to this forum.
I am attaching my output file of the command roslaunch local_planner local_planner_aero.launch after setting the rosconsole level to debug. Output.pdf (36.0 KB)
Hi ,
I am working on obstacle avoidance with PixHawk and raspberry pi following this link for avoidance GitHub - PX4/PX4-Avoidance: PX4 avoidance ROS node for obstacle detection and avoidance I installed complete method on ubuntu 18.04 with Ros-Melodic but when i run local planner i get some error showing missing parameters basically i’m not able to run the planner . Please help me in this issue .Thank you
