Need help with pymavlink to output pwm
i am using this code, how do i define the pins? i connected the servo to every pin and nothing happens… i am using orangecube connected to the pc by usb and the script run without errors.
import time
from pymavlink import mavutil
def set_servo_pwm(servo_n, microseconds):
master.mav.command_long_send(
    master.target_system, master.target_component,
    mavutil.mavlink.MAV_CMD_DO_SET_SERVO,
    0,
    servo_n + 8,
    microseconds,
    0,0,0,0,0
master = mavutil.mavlink_connection(’/dev/ttyACM0’)
master.wait_heartbeat()
for us in range(0, 1900, 50):
set_servo_pwm(1, us)
time.sleep(0.125)
master.recv_match(type=“COMMAND_ACK”,blocking=True)
print (“pix is alive”)
thanks
