I am trying to build a multi MAV system, that can perform trajectory tracking, while:
- Sharing all MAVs position on the network, to avoid crashes b/w MAVs.
Problem Faced
- Unable to find a way to set a single frame of reference for all MAVs.
My Proposed Solutions
- Using all MAVs global position, calculate the distance between vehicles and then do avoidance.
- Put offset on local_position based on starting relative positions of MAVs.
Does PX4 already have this feature or some other way anyone could suggest?
I have been playing around a little bit with mavros with the same interest: mavros swarm
Making the vehicles share a single frame is tricky, as every vehicle has a separate estimator.
I have been experimenting with a few ways on dealing with this but am now leaning towards defining a shared origin where the estimator knows the local position. It is not ready, but you can see the PR here
In this case, I think taking feedback from the global position is better because it will not drift globally with time like local position estimate does.
Making a single local position estimator may create problem in the outdoor environment due to the communication problem between MAVs and Single estimator.
