MICOAIR H743V2 FC - Is this compatible with PX4 latest version or earlier version
Please can anyone confirm whether MICOAIR H743V2 FC is compatible with PX4 version 1.16.x or 1.17,x or V1.15.x
The MicoAir H743 V2 does have a PX4 board target in the current PX4 source tree:
micoair_h743-v2_default
and there is also a corresponding:
micoair_h743-v2_bootloader
So the H743 V2 is supported in current mainline PX4.
I would be careful, however, about assuming that this means the board target exists unchanged in all of 1.15.x, 1.16.x and 1.17.x.
The clean way to answer the version question is to check the board target against the exact PX4 release tag you intend to use.
If you tell us which firmware version you actually want to run — 1.15, 1.16 or 1.17 — and whether you are building from source or expecting QGC to provide the firmware, we can verify that exact combination rather than guessing from main.
I am interested in V1.15.4 version of PX4 firmware
Thanks for clarifying.
According to MicoAir’s documentation, the H743 V2 has official PX4 support starting from v1.16.0. The manufacturer also provides older firmware builds for v1.15.2, but I haven’t confirmed a supported v1.15.4 build for this specific board.
Is v1.15.4 a strict requirement for your project, or could you use v1.16.x?
If v1.15.4 is mandatory, that may require a separate compatibility assessment, including the board configuration, drivers, bootloader and firmware build.
Best regards,
Yiğitcan
thanks…I will go with the PX4 v1.16.x build but i haven’t tested this firmware version …
Thanks for the update!
Before flashing PX4 v1.16.x, I would recommend confirming that the MICOAIR H743V2 has a supported board target in that specific PX4 release.
The STM32H743 processor alone does not guarantee firmware compatibility. The board configuration, bootloader, sensor drivers and pin mappings must also match.
If you proceed with testing, please share:
  1. The exact firmware target and build used.
  2. Whether flashing and booting succeed.
  3. Whether the IMU, barometer and other onboard peripherals are detected correctly.
  4. Any startup errors reported in QGroundControl or the PX4 console.
I would start with a bench test without propellers and avoid flight testing until the hardware initialization and actuator outputs have been verified.
If you share the results, we can help narrow down any compatibility issues.
