Question
How to run to successfully run make px4_sitl gazebo
without the error: -- No package 'bullet' found
Context
I’m trying to run PX4 stil on gazebo on macOS
Details
I have followed these instructions but at this step after running make px4_sitl gazebo
I get the follow gin error:
[29/595] Performing configure step for 'sitl_gazebo'
-- install-prefix: /usr/local
-- cmake build type: RelWithDebInfo
-- Using C++17 standard
-- ccache enabled (export CCACHE_DISABLE=1 to disable)
CMake Warning (dev) at /opt/local/share/cmake-3.19/Modules/FindPackageHandleStandardArgs.cmake:426 (message):
The package name passed to `find_package_handle_standard_args` (PkgConfig)
does not match the name of the calling package (gazebo). This can lead to
problems in calling code that expects `find_package` result variables
(e.g., `_FOUND`) to follow a certain pattern.
/opt/local/share/cmake-3.19/Modules/FindPkgConfig.cmake:67 (find_package_handle_standard_args)
/usr/local/lib/cmake/gazebo/gazebo-config.cmake:62 (include)
CMakeLists.txt:48 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Checking for module 'bullet>=2.82'
-- Checking for module 'bullet2.82>=2.82'
-- No package 'bullet2.82' found
CMake Error at /usr/local/lib/cmake/gazebo/gazebo-config.cmake:134 (message):
Error: Bullet > 2.82 not found, please install libbullet2.82-dev.
See also "/Users/julien/PX4-Autopilot/build/px4_sitl_default/build_gazebo/CMakeFiles/CMakeOutput.log".
See also "/Users/julien/PX4-Autopilot/build/px4_sitl_default/build_gazebo/CMakeFiles/CMakeError.log".
[35/595] Generating ../../logs
FAILED: external/Stamp/sitl_gazebo/sitl_gazebo-configure
cd /Users/julien/PX4-Autopilot/build/px4_sitl_default/build_gazebo && /opt/local/bin/cmake -DCMAKE_INSTALL_PREFIX=/usr/local -DSEND_ODOMETRY_DATA=ON -DGENERATE_ROS_MODELS=ON -GNinja /Users/julien/PX4-Autopilot/Tools/sitl_gazebo && /opt/local/bin/cmake -E touch /Users/julien/PX4-Autopilot/build/px4_sitl_default/external/Stamp/sitl_gazebo/sitl_gazebo-configure
[37/595] Linking CXX static library msg/libuorb_msgs.a
make: *** [px4_sitl] Error 1
What I did
I tried to find a way to install libbullet2.82-dev but the only way I found was to run sudo apt-get install libbullet2.82-dev
which I cannot do as I’m on MacOS which does not support apt-get
System
MBP Intel on MacOS BigSur 11.2.3
xcode-select version 2384
Can someone help me plz
