Has anyone been able to successfully install and configure the LightWare Lidar (LW20) on the Jetson Orin Nano? Any recommendations and suggestions would be greatly appreciated.
Thank you!
Best regards,
Mustafa
Thank you!
Best regards,
Mustafa
Hello, I was able to connect LW20/ST20C to USB port using FTDI TTL 232R 3V3 serial cable. I confirmed the connectivity. Since Lightware Studio is not supported for aarch64, I was only able test the Lidar using the sample Python that Lightware shared with me here.
Mustafa
