So I have been flying this drone for some time now. Last Friday I flew it a couple of flights and had no issue. But today it suddenly started to Oscillate after taking off around 1m. I checked everything and all are tightened no any loose parts.
What I don’t understand is there’s no any issue with the frame, nothing is loose and nothing changed after the Friday flight
Log from Friday
Friday log
Today log
Monday log
@bresch @JulianOes Could you please look into this
What is your flight controller. Is it Cube Orange / Orange PLUS
Did you add any payload before the last flight.
Did you charge the battery before take off
what is your propeller size
Else send the pic of your drone setup
When oscillation starts suddenly with no mechanical changes, I’d check these first. First, battery: a weaker or less-charged pack changes the thrust-to-voltage ratio, so check that battery voltage compensation is enabled and compare the voltage sag between Friday’s log and today’s. Second, vibration: compare the accel FFT and vibration metrics between the two logs, because a slightly cracked prop or a worn motor bearing can be invisible but still show up as a new peak. Third, gains: if the frame is large, a mid-flight change in rate gain or the dynamic notch filter (IMU_GYRO_DNF_EN) can matter. Comparing the actuator_outputs plots from both days should show which axis starts first.
Full charged batteries. Tried with multiple batteries.
Props are 22"
Batteries are all good. We checked with multiple other batteries as well.
Hi Hiran,
Thanks for confirming that you have already tested multiple fully charged batteries and that your aircraft uses 22-inch propellers with a CUAV Pixhawk V6X V2.
Since the issue persists across different batteries, I would focus next on identifying whether the oscillation originates from the control loop, mechanical vibration, or actuator response.
A few questions could help narrow this down:
Does the oscillation begin immediately as the motors produce lift, or only after the aircraft leaves the ground?
Is the oscillation primarily in roll, pitch, or yaw?
Was the aircraft flying normally with the same propellers, payload, and PX4 parameters before the issue appeared?
Have you checked the propellers, motor mounts, arm rigidity, and flight-controller vibration isolation?
Could you share the PX4 firmware version and Flight Review links for one successful flight and one flight showing the oscillation?
With those logs, I would compare:
Angular rate setpoints versus measured angular rates
Actuator or motor output commands and saturation
IMU vibration and clipping indicators
Battery voltage under load
Relevant controller and filter parameters
The timing and dominant axis of the oscillation should help distinguish mechanical excitation from control-loop instability.
I would avoid changing PID gains or disabling filters before examining the logs, especially on a large aircraft with 22-inch propellers.
If you can share both logs, we can make a more evidence-based comparison.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
Hi, thank you for your reply!
1 - Yes, when the drone after took-off
2 - Mostly seems like roll
3 - Yes, with the same payload and parameters we flew it till last Friday. This monday the issue comes
4 - Yes, disassembled the drone and checked everything, no cracks or damages on the CF plates or arms. No propeller damages. Flight controller mounted using a double-sided foam, it always has been. Also, bench tested the motors to see the RPM and all has close RPM’s at a given PWM.
5 - I attached both logs in the first post, please take a loot into them.
is your drone arms round or square ? If it is round, i need you to take off the quadcopter and check which motor is heated the most . fly only for 2 minutes or three minutes for this test
