I enabled the joystick and noticed that in the .ini file, it says it’s enabled which is fine. But is there a way I can disable that feature for specifically the joystick? I would like to have the joystick disabled no matter what the last session was.
As in, the joystick is disabled by default on QGC startup no matter what? I don’t think that feature exists…
Maybe you could make a script that sets that value in the INI file, and then change your QGC shortcut to run that script before starting QGC.
Do you by chance know where the ini file is loaded/used?
In the QGC source code? Nope, sorry.
I found that inside of the QGCApplication.cc file if you put “settings.remove(“virtualJoystick”);” within the constructor around line 290, you can remove it from the ini file on start ups.
