I’ve tried with my wifly that connects and works with my Mac but when I connect to the wifly network with my iPad it connects okay but QGround control never seems to see it. Any suggestions ?
Welcome to the QGroundControl community!
Since your WiFly connection works with QGroundControl on your Mac, the first thing I would check is whether the iPad is receiving the MAVLink traffic correctly.
Connecting to the Wi-Fi network does not necessarily mean QGroundControl has established a MAVLink connection.
A few things worth checking:
1. Local Network permission
On your iPad, open:
Settings → Privacy & Security → Local Network
Make sure QGroundControl is allowed to access devices on your local network, if it appears in the list.
2. Connection protocol
How does QGroundControl connect on your Mac?
Is it using UDP or TCP, and which port?
If the WiFly module is configured to send UDP packets specifically to your Mac’s IP address, those packets may not reach the iPad.
3. QGroundControl connection settings
If your iPad version of QGroundControl supports manual communication links, check whether you can configure the same connection protocol, address, and port used on the Mac.
For UDP, port 14550 is commonly used for MAVLink ground-station connections, but the correct port depends on your WiFly configuration.
4. WiFly configuration
Could you confirm:
The exact WiFly module or device model
Your QGroundControl version on the Mac and iPad
Whether the working Mac connection uses UDP or TCP
The IP address and port configured on the WiFly device
Also, does the iPad show any connection attempt or error message, or does QGroundControl simply remain disconnected?
With those details, we should be able to determine whether this is an iPadOS permission issue, a network routing problem, or a MAVLink connection configuration issue.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
Thank you and sorry for the belated reply!! I will try some things you suggested!!
You’re very welcome!
No worries at all. Take your time checking the settings.
If QGroundControl still doesn’t detect the connection on your iPad, just share what you find, especially the WiFly model, connection protocol (UDP/TCP), and port configuration.
I’ll be happy to help you narrow down the issue.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
