Hi Guys,
I have a model that has two aileron on each side (top and bottom) so four in total.
I wanted to map the control to the joints accordingly. i.e. right_top wing/aeleron and right botton wing/aeleron would get the control from the same input index.
I set it up to the image attached
However, with this set up, only the bottom ones gets the control…
It seems like you can only map one “<input_index>” to a “<joint_name>”
Is there a work around on this? So that one input index controls two joints?
Thank You in advance
