Hi.
How can I launch HIL widget or connect QGC to X-Plane if there is no menu bar in daily QGC?
I can’t find it anywhere else.
Hi.
I have build QGC from github source using QT Creator. The HITL widget is not available in current version 4.0.0. Last version with working HITL is 3.5.6.
Thank you for your prompt reply. I’ll try to find out if it is gone for good or just part of the transition from QWidgets. Thanks!
Did you find anything?
Is the HIL widget included in any of the newer QGC version?
I would like to run X-Plane simulation…
