Dear PX4 Community Developers and Experts,
Hello everyone!
I am currently troubleshooting my real PX4 flight controller and have encountered a critical issue with the uxrce_dds_client task: it exhibits extremely high stack usage and remains in a Waiting state. This prevents me from establishing ROS 2 communication with the flight controller.
Problem Description and Symptoms:
- I ran the offboard_control.py from px4_ros_com and found that /fmu/in has no subscribers; /fmu/out has no publishers.
- Running
ros2 topic echo /fmu/out/vehicle_statusand/fmu/out/vehicle_local_positionproduces no output. - When I check the task status using the
nsh> pscommand, the output for uxrce_dds_client is as follows:
nsh> ps
PID GROUP PRI POLICY TYPE NPX STATE EVENT SIGMASK STACK USED FILLED COMMAND
0 0 0 FIFO Kthread N-- Ready 00000000 000726 000412 56.7% Idle Task
1 1 249 FIFO Kthread --- Waiting Semaphore 00000000 001224 000292 23.8% hpwork 0x24000998
2 2 50 FIFO Kthread --- Waiting Semaphore 00000000 001576 000292 18.5% lpwork 0x240009ac
3 3 100 FIFO Task --- Waiting Semaphore 00000000 003144 002164 68.8% nsh_main
4 4 255 FIFO Task --- Waiting Semaphore 00000000 001232 000580 47.0% wq:manager
5 4 205 FIFO pthread --- Waiting Semaphore 00000000 001896 001428 75.3% wq:lp_default 0x81f15cc
422 422 90 FIFO Task --- Waiting Semaphore 00000000 001376 001084 78.7% dataman
488 4 255 FIFO pthread --- Waiting Semaphore 00000000 003120 002308 73.9% wq:rate_ctrl 0x81e51b8
746 746 237 FIFO Task --- Waiting Signal 00000000 002000 001252 62.6% ekf2 start
491 4 253 FIFO pthread --- Waiting Semaphore 00000000 002368 001808 76.3% wq:SPI1 0x81f437c
717 4 242 FIFO pthread --- Waiting Semaphore 00000000 002216 001224 55.2% wq:nav_and_controllers 0x81af980
398 4 237 FIFO pthread --- Waiting Semaphore 00000000 002776 001112 40.0% wq:hp_default 0x8197ed8
1071 1071 100 FIFO Task --- Waiting Signal 00000000 002792 001948 69.7% mavlink_if0 mavlink start -d /dev/ttyACM0 -m 2
1072 1071 175 FIFO pthread --- Waiting Semaphore 00000000 004776 001588 33.2% mavlink_rcv_if0 0x30014768
977 977 100 FIFO Task --- Waiting Semaphore 00000000 009872 009396 95.1%! uxrce_dds_client start -t serial -d /dev/ttyS3 -b p:SER_TEL2_BAUD
882 882 205 FIFO Task --- Waiting Semaphore 00000000 001936 001188 61.3% gps start -d /dev/ttyS0 -b p:SER_GPS1_BAUD
1075 1075 100 FIFO Task --- Running 00000000 002000 001492 74.6% mavlink_shell
1044 1044 230 FIFO Task --- Waiting Semaphore 00000000 003616 003060 84.6%! logger start -b 64 -t
1046 1044 60 FIFO pthread --- Waiting Semaphore 00000000 001144 000388 33.9% log_writer_file 0x300082f0
727 4 241 FIFO pthread --- Waiting Semaphore 00000000 005976 003660 61.2% wq:INS0 0x81f4354
984 984 105 FIFO Task --- Waiting Semaphore 00000000 002104 001512 71.8% navigator start
505 4 243 FIFO pthread --- Waiting Semaphore 00000000 002312 000908 39.2% wq:I2C4 0x81f434c
730 4 240 FIFO pthread --- Waiting Semaphore 00000000 005976 003660 61.2% wq:INS1 0x81f435c
733 733 140 FIFO Task --- Waiting Signal 00000000 003192 001524 47.7% commander start
1054 4 236 FIFO pthread --- Waiting Semaphore 00000000 003600 002252 62.5% wq:uavcan 0x81994a8
447 4 246 FIFO pthread --- Waiting Semaphore 00000000 002312 000896 38.7% wq:I2C1 0x81f4334
From the output above, it’s clear that:
The FILLED field shows stack usage at a critical 95.0%!, indicating an imminent or actual stack overflow, which can lead to instability or crashes.
The STATE field is Waiting, and the EVENT is Semaphore. This suggests the task is blocked, waiting for a specific semaphore to proceed with its execution.
Due to this client task not running correctly, my uxrce_dds_agent on the companion computer receives no data from the flight controller. The payload_rx counter consistently remains at 0, and ROS 2 topics fail to detect any PX4 publishers.
nsh> uxrce_dds_client status
INFO [uxrce_dds_client] Running, connected
INFO [uxrce_dds_client] Using transport: serial
INFO [uxrce_dds_client] Payload tx: 66341 B/s
INFO [uxrce_dds_client] Payload rx: 0 B/s
INFO [uxrce_dds_client] timesync converged: true uxrce_dds_client: cycle: 10707 events, 45043309us elapsed, 4206.90us avg, min 102us max 92283us 4310.698us rms
uxrce_dds_client: cycle interval: 10712 events, 4206.94us avg, min 103us max 92284us 4310.532us rms
My Environment Configuration:
■ Flight Controller Hardware & PX4 Firmware: Holybro Pixhawk 6C with PX4 v1.15.4 stable.
■ QGroundControl Version: QGC 5.0.3.
■ DDS Agent: I am running eProsima Micro-XRCE-DDS Agent on an Orange Pi AI Pro (downloaded via snap: v1.0.2+git138.0aea832).
■ Connection Method: The flight controller’s TELEM2 port (GND, TX, RX) is connected to the Orange Pi AI Pro’s UART2 port (GND, RX, TX) using a GH1.25 to DuPont female cable.
PX4 Parameter Configuration:
- MAV_0_CONFIG and MAV_1_CONFIG are disabled.
- SER_TEL2_BAUD: 921600.
- UXRCE_DDS_CONFIG: TELEM2.
Troubleshooting Steps I’ve Already Taken:
Attempted to use a source-compiled v2.4.2 Micro-XRCE-DDS Agent, with the same result.
Confirmed that the serial connection (wiring) and baud rate settings are correct.
Tested both manual startup and auto-startup methods for the uxrce_dds_client task, as well as trying other baud rates:
Manual start:
The micro_ros_agent (eProsima Agent) starts successfully on the Orange Pi. However, when performing uxrce_dds_client status checks from the MAVLink console (or via nsh> ps), the output consistently shows payload_rx as 0.
Checked the PX4 boot logs ( Manual start), but did not find any explicitly clear error messages pointing to the failure reason for uxrce_dds_client, other than its eventual Waiting state.
My Key Questions and Request for Help:
Does 95.0%! stack usage unequivocally mean a stack overflow has occurred or is imminent? In your opinion, is this stack issue the direct cause of it Waiting on Semaphore, or is the Waiting state itself leading to such high stack consumption?
What are the recommended methods to diagnose or optimize the stack usage of uxrce_dds_client within PX4 firmware?
Are there ways to further investigate the specific reason it’s Waiting on Semaphore?
Is the Waiting state indeed the reason why payload_rx remains at 0?
Any advice on how to resolve the uxrce_dds_client stack overflow, its waiting state, and the persistent payload_rx equals 0 issue would be immensely helpful. Thank you for your time and expertise!
