# Heading fixed flight path for multicopters
**URL:** <https://discuss.px4.io/t/heading-fixed-flight-path-for-multicopters/1591>\
**Created:** [October 27, 2016, 6:52am UTC](https://discuss.px4.io/t/heading-fixed-flight-path-for-multicopters/1591 "2016-10-27T06:52:29Z")\
**Posts on this page:** 1\
**Showing post:** 21
**Author:** ![hamishwillee](https://discuss.px4.io/user_avatar/discuss.px4.io/hamishwillee/32/3469_2.png) [@hamishwillee](https://discuss.px4.io/u/hamishwillee)\
**Post date:** [May 14, 2019, 2:04am UTC](https://discuss.px4.io/t/heading-fixed-flight-path-for-multicopters/1591/21 "2019-05-14T02:04:39Z")
> [@MaEtUgR](#):
> That said [MPC\_YAW\_MODE](https://docs.px4.io/master/en/advanced_config/parameter_reference.html#MPC_YAW_MODE) is worth mentioning. This parameter affects the yaw also in a survey and it will override what is planned in the mission. **Is there the need to also have more options like: “I don’t care about yaw, just keep it”, “Always keep yaw heading to north” or similar?**
Thanks. I’d leave for people here to discuss but I would think “I don’t care about yaw, just keep it” makes sense.
That said, my understanding is that the yaw is relative to the heading. So for this case when they cross the pattern, if the yaw is constant the actual direction faced will change. I.e. they can’t use this to implement the desired pattern.
You could use a setting like “Always keep yaw such that vehicle points to north” but then you end up having to have entries for every possible yaw value.
I’d think the easiest way way might be for QGC to give people the option to set a heading for the scan and then update all the waypoints appropriately.
_[View the full topic](https://discuss.px4.io/t/heading-fixed-flight-path-for-multicopters/1591)._
