Using the offboard control in mavsdk and setting an acceleration setpoint of just 5 north and 0 down and 0 east, the drone heads in the correct direction but the heading drifts anticlockwise. Does anyone know how to fix this?
I would first separate the translational command from the yaw control path.
An acceleration setpoint of (North=5, East=0, Down=0) defines the desired translational acceleration, but it does not by itself necessarily define the vehicle heading.
In particular, check what MAVSDK is actually sending for the yaw/yaw-rate field with your acceleration command. If heading is expected to remain fixed, make that yaw behaviour explicit rather than assuming the acceleration vector constrains it.
A useful isolation test would be:
hover and hold an explicit fixed yaw;
apply the same north acceleration;
check whether the yaw setpoint remains constant while the measured yaw begins drifting.
If the yaw setpoint itself moves, investigate the Offboard/MAVSDK command path. If the setpoint remains fixed but vehicle yaw diverges from it, then move downstream into the PX4 attitude/rate controller and simulator dynamics.
A short ULog from this minimal test would make the distinction very clear.
