FlightMD: Free, Open-Source Diagnostic Tool for PX4/ArduPilot/MAVLink flight logs
Hi all, I’ve been building FlightMD, a free and open-source diagnostic tool for PX4/ArduPilot/MAVLink flight logs. Upload a .ulg/.bin/.tlog and it runs 8 deterministic rule-based checks, oscillation, vibration, EKF, battery, GPS, parameters, motors, plus ascent/recovery detection for rockets and HABs, and returns a health score plus specific parameter fixes. No cloud AI in the diagnosis path, no account needed, fully self-hostable.
Rather than trust my own synthetic test fixtures, I validated it against 50 real logs pulled from PX4’s own public database, quads, hexes, VTOLs, fixed-wing, even a coaxial helicopter and a rover. Full writeup and all 50 logs are on GitHub, including where my own cross-checks disagreed with the noisy metadata.
Posting here because I’d genuinely value feedback from people who know these logs better than I do. If you’ve got a PX4 or ArduPilot log lying around, I’d appreciate you running it through and telling me where the analysis is wrong or unhelpful. There’s also an opt-in checkbox to anonymously contribute a log + its report to a growing validation dataset, if you don’t mind.
GitHub: GitHub - Praddyx15/FlightMD · GitHub
Happy to answer questions or take feedback on the specific thresholds/rules in the code.
how do you enter the log file to be analyzed on command terminal
Hi Pradum,
I reviewed the FlightMD repository and the 50-flight verification report. The use of real PX4 logs, the reproducible dataset manifest, and the transparent reporting of limitations are particularly valuable.
One area that could strengthen the validation is separating diagnostic findings from causal conclusions.
For example, in a flight ending with a failsafe, it would be useful to compare:
  • The earliest observable anomaly
  • The first behaviorally relevant divergence
  • The final failsafe or termination event
  • Whether the available log evidence is sufficient to support a root-cause conclusion
A deterministic diagnostic finding can be correct without necessarily identifying the initiating failure.
I’m working on evidence-based PX4 flight-log validation through PAMILANGA LTD and would be interested in reviewing a small number of reproducible cases against FlightMD’s output.
Also, regarding the earlier terminal question: I found the documented Python run_analysis() API, but not a dedicated CLI command in the README. A minimal command-line example could help users who prefer local analysis.
Best regards,
Yiğitcan Öztürk
PAMILANGA LTD
