I’m trying to write my own firmware loading application to interact with the stock bootloader (FMUv5 I think).
I think I’m overlooking some detail because almost everything except booting up with the new firmware is working.
I can successfully put my pixhawk 4 mini into bootloader mode using a mavlink command.
I can reboot out of bootloader mode by sending PROTO_BOOT.
I can erase the existing firmware.
When I transfer new firmware (so far just the same most recent stable firmware QGC downloads and transfers) I get back the correct CRC code.
When I try to reboot, my pixhawk 4 mini just stays in bootloader mode even though the PROTO_BOOT command responds with PROTO_OK (and I have to load new firmware using QGC to recover).
Pseudocode steps
Enter Bootloader mode
Send PROTO_GET_SYNC
Get Bootloader size using PROTO_DEVICE_FW_SIZE
Send PROTO_CHIP_ERASE
Send new firmware 1.11.2px4_fmu-v5_multicopter.px4 64 bytes (PROTO_PROG_MULTI_MAX) at a time formatted PROTO_PROG_MULTI, bytes_in_next_segment, next_piece_of_firmware_file, PROTO_EOC
Verify the CRC (calculated with spare bytes filled with 0xFF)
Send PROTO_BOOT and PROTO_EOC to reboot
Anyone see anything I’m missing or have suggestions for what to check?
