Firmware build problem. Help
Hello, I need to modify pixhawk code, for that I need to compile the code and run it to happen to build into the firmware (so I understand the principle of operation of all, if I’m wrong, correct me please). The compilation is successful, but the execution fails. Please help me fix it. I work in a virtual machine Ubuntu in Virtial Box.
1- project loading - everything is OK.
2- problems after running code.
Help me please :slight_smile:
