FFT on Pixhawk V6X
Can anyone explain to me that why CUAV Pixhawk V6X doesn’t have the **IMU_GYRO_FFT_EN ?
Is this FC incapable of running the FFT? I need to use the Dynamic Notch filter with FFT since I don’t get RPM from ESCs.
You can’t really expect a proper answer without at least mentioning what PX4 version you’re using.
Provide this context, and a full parameter list would also be helpful for others to help you.
Just using the latest 1.17 flashed through the QGC.
I just found out the problem is it’s not enabled in default. I just enabled it and the program size exceeds the flash size of this FC. So, I guess that’s why it’s not available default.
