I am trying to add a library testlib
, and a module testmod
into the px4 environment. The CMakeLists.txt
of testlib
looks like
cmake_minimum_required(VERSION 3.1)
project(testlib CXX)
add_library(testlib
src/testlib.cpp
include/testlib.h
target_include_directories(testlib PUBLIC include)
and CMakeListst.txt
does
px4_add_module(
MODULE testmod
MAIN testmod
SRCS testmod.cpp
DEPENDS testlib
But while building
$ make px4_fmu-v5_default
I’ve got the error message
[1/1219] Building CXX object src/lib/testlib/CMakeFiles/testlib.dir/src/testlib.cpp.obj
FAILED: src/lib/testlib/CMakeFiles/testlib.dir/src/testlib.cpp.obj
In file included from ../../src/include/visibility.h:85:0,
from <command-line>:0:
NuttX/nuttx/include/time.h:43:10: fatal error: nuttx/config.h: No such file or directory
#include <nuttx/config.h>
compilation terminated.
[10/1219] Generating uORB topic headers
Makefile:193: recipe for target 'px4_fmu-v5_default' failed
make: *** [px4_fmu-v5_default] Error 1
All the files testmod.cpp, testlib.cpp, testlib.h
contain minimum of code
testlib.h:
#pragma once
int func();
testlib.cpp
#include "testlib.h"
int func() { return 0; }
What is the problem?
