Failure to Ascend
Dear community,
Please revise my log via the link. Drone has failed to ascend
Thank you.
Hi swere,
Thanks for sharing the flight log.
I would first distinguish between two possible scenarios:
  1. PX4 commanded an ascent, but the vehicle could not generate sufficient thrust.
  2. PX4 did not command the expected ascent because of a flight-mode, state-estimation, or control-related issue.
The most useful signals to examine around the attempted takeoff are:
  • Vehicle flight mode and arming state.
  • Altitude setpoint versus estimated altitude.
  • Vertical velocity setpoint versus measured vertical velocity.
  • Actuator and motor output commands.
  • Battery voltage during the attempted ascent.
  • Relevant PX4 warnings, errors, and estimator status.
Could you also clarify:
  1. Which PX4 version and flight controller are you using?
  2. What vehicle type and motor/propeller configuration do you have?
  3. Which flight mode was used for takeoff?
  4. Did the motors accelerate normally while the vehicle remained on the ground, or did the motors fail to increase speed?
If the vehicle remained on the ground despite high motor outputs, I would investigate the propulsion system and thrust availability first.
If the altitude or vertical velocity setpoints did not request a climb, the investigation should focus on the flight mode, takeoff logic, and controller state.
I would avoid further autonomous takeoff attempts until the cause is understood and the propulsion configuration has been checked safely.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
Hi swere,
I downloaded and inspected your ULog.
There are several useful findings.
The vehicle was operating in Acro mode (nav_state = 10), and the motor outputs increased substantially during the attempted takeoff.
At approximately 45–46 seconds into the analyzed interval, the four motor outputs reached roughly 1860–1900 µs.
Battery current also increased significantly, reaching approximately 31.4 A, while the minimum recorded battery voltage was approximately 10.09 V.
However, the estimated vertical motion remained very limited.
The log also contains both takeoff and landing detection events, but those events do not independently establish that the vehicle achieved a successful climb.
Based on these observations, I would prioritize investigating the propulsion system rather than assuming that PX4 failed to generate motor commands.
Could you confirm:
  1. The vehicle’s total takeoff weight.
  2. Motor and propeller specifications.
  3. Battery configuration (cell count, capacity and condition).
  4. Whether all propellers are installed in the correct positions and orientations.
  5. Whether the motors rotate in the directions expected by the configured airframe.
  6. Whether the vehicle was physically restrained during this test.
Please do not repeat the high-throttle takeoff attempt until the propulsion configuration has been checked safely.
The log demonstrates increasing motor commands and substantial electrical load, but further hardware information is required to determine why the vehicle did not climb.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
