When I try to build example of MAVSDK : takeoff_and_land, I have error:
Can you help me to fix it? Thank you so much!
Yes I got the same error with the Action plugin. It seems they changed the typo. Replace the SUCCESS
to Success
in the takeoff_and_land.cpp and it should work
Thank you. I try to do as you said but It doesn’t work.
you get exactly the same error ? You might need to change it at multiple lines
Juste change where you got an error but not everywhere
My bad. Thank you very much! It work.
