Error building custom QGC
I renamed custom-example as custom, cleaned my previous build and also ran python updateqrc.py code. While building the code i faced this issue:
Code Snippet:
CustomFirmwarePlugin::CustomFirmwarePlugin()
for (int i = 0; i < _flightModeInfoList.count(); i++) {
FlightModeInfo_t& info = _flightModeInfoList[i];
//-- Narrow the flight mode options to only these
if (*info.name != _holdFlightMode && info.name != _rtlFlightMode && info.name != _missionFlightMode) {
// No other flight modes can be set
info.canBeSet = false;
sounds like one of the variables in the != statements is a QString, rather than an std::string, etc.
so you need to find which one is the QString, and call toStdString() on it.
