I went back and obtained the uorb top and top outputs under both conditions:
Without publishing sensor_data with EKF2_HGT_MODE=1
nsh> param show EKF2_HGT_MODE
Symbols: x = used, + = saved, * = unsaved
x + EKF2_HGT_MODE [128,222] : 1
TOPIC NAME INST #SUB #MSG #LOST #QSIZE
task_stack_info 0 0 1 0 2
vehicle_gps_position 0 4 4 7 1
sensor_accel 0 1 251 0 1
sensor_gyro 0 2 251 0 1
sensor_mag 0 1 251 0 1
actuator_controls_0 0 5 251 227 1
input_rc 0 3 87 81 1
sensor_preflight 0 1 251 0 1
sensor_combined 0 3 251 164 1
vehicle_magnetometer 0 3 251 164 1
manual_control_setpoint 0 3 88 5 1
rc_channels 0 0 88 0 1
actuator_controls_3 0 1 88 0 1
actuator_outputs 0 2 333 330 1
multirotor_motor_limits 0 1 333 107 1
ekf2_timestamps 0 1 251 0 1
vehicle_rates_setpoint 0 2 251 0 1
rate_ctrl_status 0 1 251 0 1
PID COMMAND CPU(ms) CPU(%) USED/STACK PRIO(BASE) STATE FD
0 Idle Task 102074 56.497 308/ 4096 0 ( 0) READY 3
1 hpwork 7775 4.708 1420/ 4076 249 (249) READY 18
2 lpwork 265 0.094 1124/ 4076 50 ( 50) w:sig 8
3 init 2912 0.000 2428/ 4076 100 (100) w:sem 3
292 top 114 1.224 1532/ 2028 255 (255) RUN 3
114 vvvvv 7537 4.519 1860/ 4076 251 (251) READY 4
117 bbbbb 4390 0.000 980/ 2028 100 (100) w:sig 3
153 sensors 13330 5.555 1660/ 2164 249 (249) w:sem 12
155 commander 2080 1.318 1804/ 3212 140 (140) w:sig 28
156 commander_low_prio 6 0.000 772/ 2996 50 ( 50) w:sem 28
158 ppppppp 7034 1.883 916/ 2012 100 (100) w:sig 4
174 mavlink_if0 11012 6.403 2044/ 2556 100 (100) READY 25
175 mavlink_rcv_if0 1232 0.659 1908/ 2836 175 (175) READY 25
250 ekf2 9599 5.932 2276/ 6572 250 (250) w:sem 23
255 mc_att_control 12591 8.192 1228/ 1660 251 (251) w:sem 16
261 mc_pos_control 635 0.376 1324/ 1876 250 (250) w:sem 9
264 navigator 20 0.000 1228/ 1764 105 (105) w:sem 15
272 logger 2657 1.600 1316/ 3524 245 (245) w:sem 24
Processes: 18 total, 6 running, 12 sleeping, max FDs: 54
CPU usage: 42.47% tasks, 1.04% sched, 56.50% idle
Uptime: 171.123s total, 102.075s idle
With sensor_data being published and EKF2_HGT_MODE=1
update: 1s, num topics: 77
vehicle_gps_position 0 4 4 3 1
sensor_accel 0 1 250 0 1
sensor_baro 0 1 250 0 1
sensor_gyro 0 2 250 0 1
sensor_mag 0 1 250 0 1
actuator_controls_0 0 5 250 229 1
input_rc 0 3 87 82 1
sensor_preflight 0 1 250 0 1
sensor_combined 0 3 250 164 1
vehicle_air_data 0 4 250 242 1
vehicle_magnetometer 0 3 250 164 1
estimator_status 0 3 125 38 1
vehicle_local_position 0 6 125 220 1
manual_control_setpoint 0 3 87 0 1
rc_channels 0 0 87 0 1
actuator_controls_3 0 1 87 0 1
actuator_outputs 0 2 331 329 1
multirotor_motor_limits 0 1 331 107 1
ekf2_timestamps 0 1 250 0 1
vehicle_attitude 0 4 250 430 1
vehicle_rates_setpoint 0 2 250 0 1
sensor_bias 0 3 125 160 1
rate_ctrl_status 0 1 250 0 1
ekf2_innovations 0 1 125 0 1
0 Idle Task 638027 44.109 348/ 4096 0 ( 0) READY 3
1 hpwork 66423 4.901 1412/ 4076 249 (249) READY 18
2 lpwork 2165 0.094 1124/ 4076 50 ( 50) w:sig 8
3 init 2954 0.000 2428/ 4076 100 (100) w:sem 3
294 top 51 1.225 1508/ 2028 255 (255) RUN 3
114 vvvvv 64904 4.995 1780/ 4076 251 (251) READY 4
117 bbbbb 4469 0.000 980/ 2028 100 (100) w:sig 3
153 sensors 89351 6.126 1660/ 2164 249 (249) w:sem 13
155 commander 18778 1.413 1828/ 3212 140 (140) READY 28
156 commander_low_prio 54 0.000 804/ 2996 50 ( 50) w:sem 28
158 ppppppp 29558 1.885 896/ 2012 100 (100) READY 4
174 mavlink_if0 89623 6.409 2044/ 2556 100 (100) READY 30
175 mavlink_rcv_if0 9886 0.754 1908/ 2836 175 (175) w:sem 30
250 ekf2 221085 16.399 4908/ 6572 250 (250) w:sem 23
255 mc_att_control 109744 7.728 1228/ 1660 251 (251) w:sem 16
261 mc_pos_control 14395 1.036 1204/ 1876 250 (250) w:sem 9
264 navigator 2758 0.188 1212/ 1764 105 (105) w:sem 15
272 logger 22030 1.602 1316/ 3524 245 (245) w:sem 29
Processes: 18 total, 7 running, 11 sleeping, max FDs: 54
CPU usage: 54.76% tasks, 1.13% sched, 44.11% idle
Uptime: 1385.192s total, 638.028s idle
From what I can tell, in ekf2_main.cpp
, there is:
const bool updated = _ekf.update();
Most of the ekf2 published messages are only published if updated
is true.
Tracking down what _ekf.update()
is took me to src/lib/ecl/EKF/ekf.cpp
where EKf::update()
is defined.
This function returns false if initialiseFilter() returns false.
Digging into initialiseFilter()
, it has the following statement:
return false;
Now, hgt_count_fail
will be true if _hgt_counter
is not large enough.
And from what I can tell (though I didn’t follow this part too well),
_hgt_counter
is dependent on baro data being present.
So the above could be a potential cause of what I’m seeing.
