Drone suddenly drops after a few seconds in POS_HOLD and STABILIZED mode
Hello PX4 community,
I am facing an issue with my quadcopter where the drone suddenly drops after a few seconds of flight. I am trying to understand the root cause.
Problem Description
  • The drone arms and takes off normally.
  • It hovers for a few seconds (around 3–6 seconds).
  • After that, the drone suddenly loses altitude and drops quickly.
  • This happens in both:
    • POS_HOLD mode
    • STABILIZED mode
Observations
  • Motors spin normally during takeoff.
  • The drone appears stable initially.
  • After a few seconds, thrust suddenly reduces and the drone falls.
  • I checked logs and noticed something related to hover thrust estimation, but I am not sure if it is the main cause.
Flight Controller & Setup
  • Flight Controller: MICOAIR_H743_V2
  • Firmware: PX4
  • Frame: Quad
Flight Modes Tested
  • POS_HOLD
  • STABILIZED
Both modes show the same issue.
And also this is not only with one i built the 3 quad 7inch, 10inch, 13inch same issue in all
takeoff then hold for few seconds then motor stop and drone drop.
Please help me to fix this issue
Logs
I have attached the flight log here for analysis.
Thank you
Flight Review - Quadrotor3.pdf (2.6 MB)
