Drone does not follow trajectory height and speed
My drone in the q ground control does not seem to follow the speed or height i tell it to go. Any pointers would be great please. I am using ros2, px4 and q ground control.
Here is code
class ReconControl(Node):
def init(self, namespace):
super().init(‘recon_control’)
    qos_profile = QoSProfile(
        reliability=QoSReliabilityPolicy.RMW_QOS_POLICY_RELIABILITY_BEST_EFFORT,
        durability=QoSDurabilityPolicy.RMW_QOS_POLICY_DURABILITY_TRANSIENT_LOCAL,
        history=QoSHistoryPolicy.RMW_QOS_POLICY_HISTORY_KEEP_LAST,
        depth=1
    self.status_sub = self.create_subscription(
        VehicleStatus,
        f'/{namespace}/fmu/out/vehicle_status',
        self.vehicle_status_callback,
        qos_profile
    self.local_position_sub = self.create_subscription(
        VehicleLocalPosition,
        f'/{namespace}/fmu/out/vehicle_local_position',
        self.local_position_callback,
        qos_profile
    self.vehicle_command_publisher_ = self.create_publisher(
        VehicleCommand,
        f'/{namespace}/fmu/in/vehicle_command',
        10)
    self.publisher_offboard_mode = self.create_publisher(
        OffboardControlMode,
        f'/{namespace}/fmu/in/offboard_control_mode',
        qos_profile)
    self.publisher_trajectory = self.create_publisher(
        TrajectorySetpoint,
        f'/{namespace}/fmu/in/trajectory_setpoint',
        qos_profile)
    self.publisher_coords = self.create_publisher(
        Point,
        f'/{namespace}/fmu/out/recon_coords',
        qos_profile)
    timer_period = 0.02  # seconds
    self.timer = self.create_timer(timer_period, self.cmdloop_callback)
    self.dt = timer_period
    # Circle parameters
    self.radius = 500.0  # meters
    self.linear_velocity = 90  # meters per second
    self.altitude = 60.0  # Altitude in meters
    self.angular_velocity = self.linear_velocity / self.radius
    self.theta = 0.0  # Angle for circular motion
    self.nav_state = VehicleStatus.NAVIGATION_STATE_MAX
    self.arming_state = VehicleStatus.ARMING_STATE_DISARMED
    self.arming_timer = self.create_timer(5.0, self.arm_vehicle)  # will activate function after 5 secs
def arm_vehicle(self):
    if self.nav_state == VehicleStatus.NAVIGATION_STATE_OFFBOARD:
        arm_command = VehicleCommand()
        arm_command.command = VehicleCommand.VEHICLE_CMD_COMPONENT_ARM_DISARM
        arm_command.param1 = 1.0  # means arm
        arm_command.confirmation = 0  # no further confirmation
        arm_command.from_external = True
        self.vehicle_command_publisher_.publish(arm_command)
        self.get_logger().info('RECON Vehicle armed.')
def vehicle_status_callback(self, msg):
    self.get_logger().info(f"RECON NAV_STATUS: {msg.nav_state} - offboard status: {VehicleStatus.NAVIGATION_STATE_OFFBOARD}")
    self.nav_state = msg.nav_state
    self.arming_state = msg.arming_state
def local_position_callback(self, msg):
    self.current_x = msg.x
    self.current_y = msg.y
    self.current_z = msg.z
    # Publish coordinates
    coords_msg = Point()
    coords_msg.x = self.current_x
    coords_msg.y = self.current_y
    coords_msg.z = self.current_z
    self.publisher_coords.publish(coords_msg)
def cmdloop_callback(self):
    # Publish offboard control modes
    offboard_msg = OffboardControlMode()
    offboard_msg.timestamp = int(Clock().now().nanoseconds / 1000)
    offboard_msg.position = True
    offboard_msg.velocity = False
    offboard_msg.acceleration = False
    self.publisher_offboard_mode.publish(offboard_msg)
    if self.nav_state == VehicleStatus.NAVIGATION_STATE_OFFBOARD and self.arming_state == VehicleStatus.ARMING_STATE_ARMED:
        x = self.radius * np.cos(self.theta)
        y = self.radius * np.sin(self.theta)
        z = -self.altitude
        trajectory_msg = TrajectorySetpoint()
        trajectory_msg.position = [x, y, z]
        trajectory_msg.yaw = self.theta  # Keep yaw aligned with the circle
        self.publisher_trajectory.publish(trajectory_msg)
        # Update theta for the next iteration
        self.theta += self.angular_velocity * self.dt
        if self.theta >= 2 * np.pi:
            self.theta -= 2 * np.pi
def main(args=None):
rclpy.init(args=args)
namespace = ‘px4_1’
recon_control = ReconControl(namespace=namespace)
rclpy.spin(recon_control)
recon_control.destroy_node()
rclpy.shutdown()
if name == ‘main’:
main()
