In my TF tree, I have a defined “map” frame and every other frame is branched off the map
frame. The drone starts at the odom
frame and odom
frame doesn’t coincide with the map
frame. For a type of application I’m working on the transformation from odom
to map
is not static, i.e., the odom
frame moves in the map
frame. In theory, this is fine, it doesn’t violate ROS REPs. But I noticed that the drone gets unstable (I’m seeing oscillations) and slowly dirfts away in a certain direction whislt it’s supposed to hold its position. I check the Autopilot SW, I was trying to find if there’s any assumption that the odom
is statically linked to the map
frame.
