Cube Orange Not Communicating Properly with GCS
To start with we are using an off the shelf drone that comes with a proprietary 2.4 Ghz radio and then another RFD900X radio. The RFD is used to connect to a proprietary GCS that is just a reskinned QGC software with some custom settings and configurations added. What we are attempting to connect to it is what is typically a “plug and play” cellular C2 connection. This connection simply uses a TELEM port to talk to the autopilot and can send and receive MAVLink messages. It does not do anything with those messages is the important part, it is just point to point so it should just be behaving like a bridge between the autopilot and GCS.
The issue we are having is that the connection will not connect via this third party connection and will just connect via the original radios that came with the drone. I can swap the TELEM ports of the radios and they will still work and I have tried both TELEM ports as well with the third party connection. Baud rate does not matter as the third party device defaults to 57600 and then if it doesn’t have a solid connection it will start trying different rates until it gets a good connection. The TELEM port we are trying to connect to is already set to 57600 so it shouldn’t need to hop regardless.
Now when connecting to the GCS with the third party connection I can get half of the parameters downloaded and it will fail to capture them. However it will still receive updates from the drone’s autopilot whether it is changing state of the generator on board or changing flight modes I can see it on the GCS but then I can’t do anything on that same GCS to change that stuff using the third party connection. We have gone through multiple types of trouble shooting and the thing we have come to think is that there is either something wrong with that specific autopilot and it’s configuration or a parameter that is limiting the types of connections on the autopilot.
The only real head scratcher that we have at this point is that trying to do a direct cable connection to the autopilot would not work on the proprietary GCS but when we went over to Mission Planner it worked with no issues.
A short list of what we have tried:
  • Tested with a secondary autopilot (cube black) and that worked exactly as expected with no issues.
  • Pulled tlogs and .bin from the autopilot and GCS to determine if the messages were even being attempted to be sent and if they were being received or not. What we determined is that the messages were being passed along but the autopilot either didn’t receive them or rejected them.
  • Changed the firmware on the cube black to the cube orange and flashed the parameters. This allowed connection on MP, QGC and the proprietary GCS. However it acted as though the parameters didn’t fully download and thus didn’t let us change the vehicle parameters at all.
Hi DTRON,
Welcome to the PX4/Dronecode community.
Your troubleshooting results are particularly interesting because the cellular link is not completely disconnected: the GCS receives telemetry and state updates, but parameter synchronization and command execution are unsuccessful.
That suggests it would be useful to separate three possible failure points:
  1. Bidirectional MAVLink transport
  2. Autopilot-side message acceptance or routing
  3. GCS parameter synchronization and command handling
Since you mentioned Cube Orange and Cube Black, I assume the vehicle is running ArduPilot. Could you confirm the exact firmware version?
I would suggest the following checks before changing additional parameters:
1. Capture MAVLink traffic on both sides of the cellular bridge.
For a parameter request, verify whether the GCS sends PARAM_REQUEST_LIST, whether it reaches the autopilot, and whether the corresponding PARAM_VALUE messages return successfully.
For commands, check the target system/component IDs and whether the autopilot returns a COMMAND_ACK.
2. Compare the working RFD900X link with the cellular link.
If possible, use the same GCS and autopilot configuration while changing only the transport. This should help identify whether the problem follows the communication path.
3. Verify the ArduPilot serial and MAVLink configuration.
Check the relevant SERIALx_PROTOCOL, SERIALx_BAUD, MAVLink signing configuration, and any applicable GCS/system-ID restrictions.
4. Investigate parameter transfer behavior.
A partial parameter download can indicate packet loss, missing responses, routing problems, or incompatibility in the GCS parameter handling.
It would also be useful to know whether the cellular bridge uses UDP or TCP, whether it is transparent in both directions, and whether any MAVLink routing or filtering occurs.
One important distinction: receiving telemetry does not necessarily prove that commands are reaching the correct MAVLink target or being accepted.
Could you share:
  • Exact ArduPilot firmware version
  • Cellular C2 device model
  • MAVLink version and transport protocol
  • Relevant serial-port settings
  • Whether COMMAND_ACK messages appear in the logs
  • Whether standard QGroundControl behaves differently from the proprietary GCS over the same cellular link
I would avoid disabling signing or other security controls as a troubleshooting shortcut.
With synchronized captures from the GCS and autopilot sides, we should be able to identify where the message exchange first fails.
Best regards,
Yiğitcan Öztürk
PAMILANGA LIMITED
