Communication between drones on autonomous flight
Hey guys, simple question here, is it possible to share attitude data between two pixhawks using XBEE modules?
If so, how would I go about doing that, what methodologies can I utilize?
Could you explain what you are trying to do? and why you want to specifically use Xbee?
what does 'sharing attitude data` mean? does it mean that they are sharing the attitude estimates?
Thanks for the fast response… what I am trying to achieve is to program a pair of drones that act as master and slave. The slave follows the masters attitude changes i.e. fly in the same manner as the master. What I thought of doing was to get all attitude changes from the master, and send them to the slave real-time through the XBEEEs where the slave will react accordingly…Is it possible?
@nadishancosta Technically yes it is possible. On how you want to implement it will vary depending on what you want
